CONVERT WF FOR GTS2MINI
Lih
Post by Lih »
Hello, could someone convert this wt to the gts 2 mini please? It's so pretty!
I've tried through WFMaker, but I don't understand much about it. :(
https://amazfitwatchfaces.com/gts/view/10696
- Black & Pink/Purple Versions
Thank you very much!!
Has thanked: 441 times
Been thanked: 2142 times
Lih wrote: 27 Oct 2024, 16:05
This watch face I have not tested with real devices because I do not have it.
All creations are tested with the program used to create it.
If the watch face does not work as shown in the sample image, I cannot make any additional changes.
Those who test it, please manage the risk by yourself.
You can find the device used to create the watch face at
viewtopic.php?p=12537#p12537
Download : ( Try to Fix BG not show )
viewtopic.php?p=19231#p19231
Lih
Post by Lih »
Hello @asoo !
It didn't work. Only the numbers appeared and not the design.
But thank you so much for your time spent helping me.
Lih wrote: 28 Oct 2024, 19:08
Hello @asoo !
I checked the Blackground part that was created with the latest editor, it seems that it has changed from the previous version, which may cause the problem of not showing BG, so I went back to the old version and got a new pack again.
However, I am not sure if it will work properly. You have to test it yourself again. You can download it from this post or go back to the old post.
AD_FixBG.bin
(765.18 KiB) Downloaded 158 times
Lih
Post by Lih »
Worked!
Thank you very much! :D
