Page 1 of 1
Port for GTR 4
Posted: 09 Aug 2024, 17:49
by mrbutthead
Hi everyone, Please port this watch face to GTR 4. Thanks.
https://www.facer.io/watchface/A0RK1IJ1 ... ilqmarshal
Re: Port for GTR 4
Posted: 10 Aug 2024, 09:16
by asoo
mrbutthead wrote: 09 Aug 2024, 17:49
VIGILANT2_CLPlus_GTR_4.zip
(293.46 KiB) Downloaded 134 times
Re: Port for GTR 4
Posted: 10 Aug 2024, 09:47
by amazfitfacesafrica
Very nice watchface. Is it possible to make it for gtr3 pro? I try to convert myself but with no success.
Re: Port for GTR 4
Posted: 10 Aug 2024, 09:59
by mrbutthead
@asoo thanks man
Re: Port for GTR 4
Posted: 10 Aug 2024, 11:40
by asoo
amazfitfacesafrica wrote: 10 Aug 2024, 09:47
You should have mentioned more about how you couldn't convert, what problems you encountered that made it impossible, you just said it couldn't, I couldn't fix the problem directly either.
I'm not sure why you can't convert it.
I tested it and it converts normally and works.
Except you can't show Compass because zeppOS 1 can't use compass on screen.
When you unpack it you won't find Weather icon in editor because it uses user_script to handle it. But when you pack it as watchface and bring it use, you will find Weather icon on real device.
Re: Port for GTR 4
Posted: 10 Aug 2024, 11:49
Thank you for info. The icon weather indeed not showing in editor and i suppose something is wrong with convert but you are right, in reality weather icon appears,. Thank you.
