How to change color of rotate hour?
cobz
Post by cobz »
Hi, i'm noob , i create a watchface
with 2 zont to change color first (power, swoosh and circle) ok but I can't create the script to change the hour color (normal_hour_TextRotate). I attach my script file, help me please.
Nike RZ302_JS.zip
Watch
(952.49 KiB) Downloaded 81 times
user_functions.js
script
(3.2 KiB) Downloaded 70 times
Has thanked: 429 times
Been thanked: 2132 times
Example of edited file Changing color of "Text Rotate"
Note for unpack :
If who want to unpack this file with Sasha's edit program, you must delete the line. "//start of ignored block" in the file index.js
on the part "user_functions.js"
// start user_functions.js
//start of ignored block   <-----  Delete this line
// end user_functions.js
Because it is expected that the program uses "//start of ignored block" as some requirements for creating scripts, so when it is in the user_functions.js may cause the unpacking process to not work properly.
cobz
Post by cobz »
thanks a lot, great job
