Page 1 of 1
Convert request for Amazfit GTS 4 Mini!
Posted: 21 May 2024, 16:31
by Ny666
Hello there! Could somebody please assist with converting this watch face to be compatible with the Amazfit GTS 4 Mini?
https://amazfitwatchfaces.com/gts/view/8395
Re: Convert request for Amazfit GTS 4 Mini!
Posted: 22 May 2024, 11:51
by asoo
Ny666 wrote: 21 May 2024, 16:31
Because p i p b o y has copyright.
If I remember correctly, there was a complaint from the copyright owner, p i p b o y, regarding copyright infringement by using his work. published without permission, So that is reason that the link you attached is a private link.
They are not displayed on the web page. The only access is through a direct link.
In order not to cause trouble to the web, therefore, if this watch face, once the conversion is complete, may not be posted in this Topic.
Please check your PM.
( Private Messages )
Posted: 22 May 2024, 12:44
by Ny666
Thank you so much, that makes sense
I appreciate you taking the time to do this!
