Huawei Watch Fit 3
Jolly Roger
- Has thanked: 2 times
Huawei Watch Fit 3
Hi.
Is there any possibility to create a download section for the new Huawei Watch Fit 3?
Are latest huawei watch models still supported by creators?
Thanks in advance for your answers.
I'm interested to Fit 3 watchface! Will There a possibility to have a specif area for that?
Thank you
Thank you
tanapatwin
I hope there are more Huawei Watch Fit 3 watch faces available on this website.
buraklarca
I'm waiting for this page too. I hope the support page will be opened as soon as possible. I am also waiting for a support program from my software developer friends for this watch. Enjoy your work.
aditya3524
- Has thanked: 1 time
- Been thanked: 2 times
Hello All,
Like everyone here, I was in the same boat. The stock watch faces fall short on my expectations and was looking for custom watch faces.
I did some digging, googled a bit and was able to create custom watch face for watch fit 3.
Currently, the default theme studio provided by huawei does not support 480x408 res for watch fit 3 but we can still create custom watch faces using 466x466 res : )
I have attached a few custom watch faces inspired by pixel watch faces here.
For anyone who is interested in applying them -
1. Find the huawei moded apk from telegram group. The ones on the website dont support watch fit 3 yet.
2. After installing the app, you should be to able to pick a hwt file and apply it on the watch. Note that this process is a bit flaky. If the app fails to apply the watch face, kill the huawei service, restart the app and apply. I am unable to find the exact steps that work so its trial and error as of now.
Happy tweaking!
Happy tweaking!
- Attachments
- awfGreen.hwt
- (300.09 KiB) Downloaded 2260 times
- awfBlue.hwt
- (341.06 KiB) Downloaded 1322 times
Great Job mate. We are waiting to a dedicated Watch Fit 3 page!aditya3524 wrote: 11 Jun 2024, 05:34Hello All,
Happy tweaking!
Where can i find the telegram group?aditya3524 wrote: 11 Jun 2024, 05:34Hello All,
Happy tweaking!
Has anyone progressed on this? I'm planning on buying this watch but only if we can design our own watch faces!
As far as I know the tool "facemaker" supports it:
https://buymeacoffee.com/facemaker
I'm then using the open source app GadgetBridge to upload these watchfaces to my fit3.
So I don't need a hacked app from some suspicious source.
GadgetBridge is either available from their website or through FDroid.
For the fit3 you have to install the nightly version as the current stable version does not yet support all fit3 watchfaces.
Hi, do you know if Gadgetbridge and official Huawei app can be installed both at the same time? I would like to use Gadgetbridge only for modded watchfaces upload and the official app for all other thingsTrinnox wrote: 05 Aug 2024, 06:46As far as I know the tool "facemaker" supports it:
The smartwatch can't stay connected to both apps at the same time, but you can simply do the followings steps (as I did) to keep using Health app:GIOBIN wrote: 29 Aug 2024, 08:26Hi, do you know if Gadgetbridge and official Huawei app can be installed both at the same time? I would like to use Gadgetbridge only for modded watchfaces upload and the official app for all other thingsTrinnox wrote: 05 Aug 2024, 06:46As far as I know the tool "facemaker" supports it:
- unpair the smartwatch from Huawei Health app
- pair with GadgetBridge (only Nightly version currently support watchfaces install) using authentication with Huawei ID to avoid smartwatch reset
- load your watchfaces
- then unpair from GadgetBridge and pair again with Health app
Following this steps the smartwatch don't need any reset and the watchfaces installed will keep working properly
You can check the instructions on this video to use auth ID on Gadgetbridge pairing https://www.youtube.com/watch?v=GL1CnhGJTcw
Hope I've been helpful
