Página 1 de 1
GTS 4 watchface on GTS 4 Mini
Publicado: 10 Mar 2024, 10:03
por SpaceCadet1985
Just a really quick one. Will a face tagged for the GTS 4 work on a GTS 4 Mini?
Re: GTS 4 watchface on GTS 4 Mini
Publicado: 10 Mar 2024, 11:13
por asoo
SpaceCadet1985 escribió: 10 Mar 2024, 10:03
If you don't convert, it won't work properly because, if I'm not mistaken, GTS4 and GTS4mini have the following differences:
1. Uneven screen size
2. The encoding of images is not the same. GTS4 uses type1. GTS4mini uses type2.
3. Different ZeppOS version GTS4 2.1 GTS4mini 1.0 In this section, if you use the GTS4 dial that uses certain types of animation, it may result in that animation not working on GTS4mini.
Therefore, if you want to use GTS4 with GTS4mini, you must convert it first.
Recommended to use "Watch face editor for Amazfit watch on ZeppOS"
To convert .
However Because the screen size X, Y is different, after converting, it may be necessary to re-edit the X,Y points to suit the use.
Publicado: 10 Mar 2024, 16:33
por SpaceCadet1985
Thanks! I haven't bought either device yet but this helpful thank you
