Page 1 of 1
Port for GTR 4
Posted: 25 Feb 2024, 23:44
by mrbutthead
Hello. Please port this WF for GTR 4.
https://play.google.com/store/apps/deta ... ign.stylez
Re: Port for GTR 4
Posted: 27 Feb 2024, 08:25
by asoo
mrbutthead wrote: 25 Feb 2024, 23:44
- This watchface not function change color
- This watchface have functions change Element steps, distance, calories, heart rate by click on icon steps, distance, calories, heart rate
This watch face can be unpacked with Sasha's editor.
This file downloaded from web and converted with editor 10.3. Tested on simulator. Can change colors like Amazfit Balance version.
69D_STYLEZ_digital_GTR_4_B.zip
(636.03 KiB) Downloaded 125 times
Re: Port for GTR 4
Posted: 27 Feb 2024, 10:23
by mrbutthead
@asoo awesome, thanks
Re: Port for GTR 4
Posted: 27 Feb 2024, 15:10
by mrbutthead
@asoo Can I have a balance version with changing colors?
Re: Port for GTR 4
Posted: 27 Feb 2024, 16:26
by asoo
mrbutthead wrote: 27 Feb 2024, 15:10
You can convert by Sasha's editor
Re: Port for GTR 4
Posted: 27 Feb 2024, 16:31
by mrbutthead
@asoo I tried converting, the color doesn't change for me
Re: Port for GTR 4
Posted: 27 Feb 2024, 17:16
by asoo
mrbutthead wrote: 27 Feb 2024, 16:31
Which editor version do you use to convert? I tested it using editor Version 10.3 and it can convert to GTR4 correctly.
Download :
viewtopic.php?p=17631#p17631
Re: Port for GTR 4
Posted: 27 Feb 2024, 17:21
by mrbutthead
I also use this version, the conversion works fine, but the color on the watch does not change
Re: Port for GTR 4
Posted: 27 Feb 2024, 17:24
by mrbutthead
@asoo your version works great. Thank you very much
Re: Port for GTR 4
Posted: 27 Feb 2024, 17:26
by asoo
mrbutthead wrote: 27 Feb 2024, 17:21
I think the function I used in the script can be used with any version of zeppOS. If you can't change the color, I can't make any changes either because I don't have a GTR4 to test.
I tested with Balance ZeppOS 3.5 and it worked normally.
Re: Port for GTR 4
Posted: 27 Feb 2024, 17:28
by asoo
mrbutthead wrote: 27 Feb 2024, 17:24
I didn't edit anything further, I just downloaded it from the web and converted it.
It's the same file that's on the web.
