Page 1 of 1
Can Watchface Maker create clickable/tapable areas? [SOLVED]
Posted: 23 Feb 2024, 20:10
by BenS
Hi There,
Sorry if this is easy but how do you create tapable areas for watch faces?
I have heart rate, battery, steps and date - can the Watchface Maker web app do this? I can't see options in Watchface Maker or mention of it in the official docs sorry.
Any help much appreciated. Cheers, Ben
Re: Can Watchface Maker create clickable/tapable areas?
Posted: 24 Feb 2024, 03:27
by asoo
BenS wrote: 23 Feb 2024, 20:10
Hi There,
In Watchface Maker, there is a section for creating "shortcuts."
It's called a "hot zone" but I'm not sure if it works properly. Because I haven't used it for a long time.
However, there are many elements that cannot be created as shortcuts in Watchface Maker because they are not supported, such as calendars.
If you want to make those shortcuts, you must manually add them with a custom script to the index.js file or use an editor that supports this, for example:
"Watch face editor for Amazfit watch on ZeppOS."
by use element "Botton" to create a shortcut that is not available in Watchface Make
such as calendar , sport list ................. and many more
Posted: 24 Feb 2024, 05:04
by BenS
Perfect, thank you.
