Request port of this starfield watch face trex2
DarkN1ghtmar3
Post by DarkN1ghtmar3 »
I found this cool watch face it was on the facer app on android would love to see it on my trex2
Has thanked: 436 times
Been thanked: 2137 times
There were many elements that were not possible in Trex2, so I adjusted some elements to create this watch face.
If you like it, you can download and use it.
Earths_Moon_FAOD_T_Rex_2_V2.zip
(304.01 KiB) Downloaded 297 times
Version 3 Add BT icon :
Earths_Moon_FAOD_T_Rex_2_V3.zip
(303.94 KiB) Downloaded 329 times
Has thanked: 132 times
Been thanked: 21 times
Post by taw_bip »
asoo wrote: 14 Sep 2023, 15:51
Is this because of the Zepp OS version? Because T-Rex 2 recently got v2.1.
taw_bip wrote: 15 Sep 2023, 18:23
The element I'm talking about is the mobile battery display.
As far as I know terx2 , GTR3 do not have this component.
DarkN1ghtmar3
Looks nice only thing missing is a display to show it’s connected to Bluetooth could you replace the heart icon with a Bluetooth icon
DarkN1ghtmar3 wrote: 16 Sep 2023, 14:43
Please read the "spoiler" carefully.
viewtopic.php?p=16327#p16327
I got the port as per the original you attached. In your first request then
If you want to make any changes from the work I ported, please do so yourself.
thank you
But this time I'm going to add Bluetooh, adding it under the heart icon.
Next time if you want to make any request, please specify what you want in detail.
So that those who want to port for you don't have to do the same work over and over.
Download at the original thread I posted.
And please read the spoiler carefully.
armthanagorn
Post by armthanagorn »
Hell asoo i downloaded already ,Thank you so much to convert
but The lunar orbital system does not work.
armthanagorn wrote: 01 Dec 2023, 01:44
Sorry I can not test because I don't have Trex2
About 30 people have downloaded it and used it. I haven't received a report of the problem as you mentioned. So I'm not sure what the reason for the problem is.
The moon phase system in this dial uses 8 images.
Therefore, the image display will not be as detailed as 30 images.
But you said it doesn't work. I don't know how to help because, as I said, I don't have Trex2, but as I tested on the Simulator and Editer's program. It works normally.
And there may be another possible reason: the weather information in zepp is not synced with the watch or there is no information. Waxing moon in weather information in that region
But if you use another watch face and there's no problem, then I can't do anything.
Because I can't test it on the actual device.
