Requesting porting watch face gtr4/gts4 mini
Roger1976
Post by Roger1976 »
pls port this gtr4 watch face to a gts4 mini watch face:
https://amazfitwatchfaces.com/gtr/view/35138
Thank you.
Has thanked: 441 times
Been thanked: 2142 times
Before downloading, please understand the following.
- This watch face only performs size conversion.
- The script about graph is same as original
- I don't have a GTS4mini so can't test it on a real device.
- I'm not sure if GTS4mini can display script graph or not.
- All tests I can only do on the simulator.
Graph lines are not displayed in the preview. But tested with the equipment used.
ZeppOS2, the graph shows normal.
Therefore, if this dial Unable to work or not working properly
I won't edit again. if want to change or fix anything please do it by yourself
To use this dial, please manage your risk yourself. I can't take any responsibility.
Pulse_Monitor_GTS4mini.zip
(68.1 KiB) Downloaded 63 times
Note :
The requester has not yet asked permission from the owner . Therefore, if the owner of the work wants it deleted. I will take action immediately and without conditions.
