How can i open an .png images after unpacking them?
Was trying to make custom watchface and wanted to check out how the numbers would look like in .png files but they wouldn't open, is there's a way to open them?
- Has thanked: 420 times
- Been thanked: 2121 times
png in pack is PNG ( amazfit format ) if you want to edit you must to convert to normal PNG
You can use this utility to convert :
viewtopic.php?p=14958#p14958
Or use this program to unpack and edit layout :
Alright... What if i use Mi Fit, i wanna create a watch face for Mi Band 6 and looking at this programm looking like this is not what i need at allasoo wrote: 09 Jun 2023, 11:55png in pack is PNG ( amazfit format ) if you want to edit you must to convert to normal PNG
Since you didn't mention in the first post which device you are using, I looked at the picture you attached and saw folder "assets" which is same as GTR 3 / 3 pro / 4 , so I replied that way.seeya wrote: 09 Jun 2023, 13:41
If it's Mi Fit, I no idea for that.
But as far as I can find on the web, there is a topic related to the Mi band 6 editor, follow the link.
viewtopic.php?p=8477#p8477
I see, thanks! Looks like a perfect tool, the only thing i couldn't understand is how to create a time, maybe you have any ideas cuz i'm so confused
Sorry, I can't give you advice on this part because I don't use mi band. I recommend you to ask the questio it , at the topics in related, There should be someone who can help solve your problem exactly to the point, such as this topicseeya wrote: 11 Jun 2023, 09:50I see, thanks! Looks like a perfect tool, the only thing i couldn't understand is how to create a time, maybe you have any ideas cuz i'm so confused
Or this
viewtopic.php?t=3078
