Upload a new watchface for Amazfit GTR4
MetalSpirit
Hi There
I'm new to Amazfit fit Watchfaces, but I have a couple ones I created for Wear OS, and I am re-creating them on watchfaces.zepp.com.
I downloaded the zap file. How can I upload it here?
Thanks you for any replys.
- Has thanked: 441 times
Zap ?????MetalSpirit wrote: 17 Nov 2022, 12:42Hi There
Are you mean zab or not ?
If yes zab is a zip format you can use winrar to uncompress it .
After you uncompress you can see file .zpk , it is a zip format too
you can use winrar uncompress it again , after you uncompress .zpk you will see "Device.zip" this file is your watchface you can use this file sync to your watch
- GIK-Team
- root
- Has thanked: 1184 times
- Been thanked: 281 times
- Extract the zab file using any program that works with zip archives.
- Inside, extract the zpk file in the same way.
- Rename the device.zip file (found in this zpk) as you like and upload it to the site without unpacking.
MetalSpirit
Thanks... Yes.. It was ZAB!
It's uploaded. MAF Collection - Classic.
Why doesn´t he show up on the recent watchfaces?
- GIK-Team
- root
All new watchface developers go through moderation. At the moment, I see that your watch face has successfully passed moderation and is already available in the catalog for public access.MetalSpirit wrote: 17 Nov 2022, 14:26Thanks... Yes.. It was ZAB!
MetalSpirit
- mokady
- Has thanked: 1 time
I'm following these steps but after unzip the zab file i find another zip file inside which when decompressed i get the 'source.bin'GIK-Team wrote: 17 Nov 2022, 14:08MetalSpirit wrote: 17 Nov 2022, 12:42Hi There
I uploaded it to the catalogue but when i installed it, it is very crappy!
with extracted device.zip file i can not edit watch face using watch face editor by SashaCX75GIK-Team wrote: 17 Nov 2022, 14:08MetalSpirit wrote: 17 Nov 2022, 12:42Hi There
as i created a watchface using web
- GIK-Team
- root
This discussion discusses uploading a watch face to a directory, not editing it.Abhiie wrote: 15 Mar 2023, 17:51with extracted device.zip file i can not edit watch face using watch face editor by SashaCX75
