Page 1 of 1
How to unpack a .bin file?
Posted: 12 Nov 2022, 00:13
by Torinast
I bought a chinese smartwatch and it can download watchfaces from the app. I noticed it uses .bin files like other smartwatches and I was wondering how could I unpack these files?
I wanna try and see if its possible to create custom WF for this watch but first I need to unpack this .bin file, could anyone help me with this?
I added the bin file in question
Re: How to unpack a .bin file?
Posted: 12 Nov 2022, 05:30
by asoo
If you don't have the example file you're talking about.
I think those who want to help you Might not be able to answer any questions.
I suggest you attach the file you mentioned.
Posted: 17 Nov 2022, 02:27
by Akam
I Actually Don't Know How Open The.bin Files But I Thought You Might Be Charged The File Format Like RAR Or Zip By An Application In Android Or Pc Then Extract File, You Also Can Change The File Format Manually, For This Way You Erase The bin Until Dot And Most rar Or zip Writing Manually Like This .rar Or .zip
For Extracting This Files You Better Use Pc And Open File.
