Pagina 1 di 1
Watch face doesn't display correctly [T-Rex Pro]
Inviato: 06 lug 2022, 22:14
da puddum
I created and uploaded a new face https://amazfitwatchfaces.com/t-rex/view/10000 using Sasha's editor v7.3. It installs without any errors and the preview image is displayed properly but the actual face on the watch is simply a blank black screen with a small cluster of white pixels in the top left corner.
Anyone know what I've done wrong?
Re: Watch face doesn't display correctly [T-Rex Pro]
Inviato: 07 lug 2022, 09:02
da asoo
puddum ha scritto: 06 lug 2022, 22:14
I can't verify it on the actual Device because I don't have it.
But when check it out, your PNG looks like it's compressed.
which the watch cannot read those image files
This is an example of an uncompressed png.
If you can sync this watchface and watchface can use normal , The problem is probably the format of the PNG you used to create the FW.
lpclean_packed_packed.bin (not work)
The PNG image used to create it should format look like this:
and non-compress
Inviato: 07 lug 2022, 12:13
da puddum
Still getting the same result using lpclean_packed_packed.bin
Inviato: 07 lug 2022, 14:28
da asoo
puddum ha scritto: 07 lug 2022, 12:13
If I'm not mistaken, in the GTR47mm if the main screen doesn't use the first image file, it doesn't display. But I'm not sure Will it be the same with Trex-Pro as well?
The attached file has changed the main screen to 0001.png.
Please try this WF
lpclean_packed_packed2.bin
(1.65 MiB) Scaricato 184 volte
Inviato: 07 lug 2022, 14:51
da puddum
Solved! Thank you so much
