linux terminal watchface
sfreud
Post by sfreud »
i need some help with a watchface which i try to convert from gtr 47mm to gtr2; everithing is ok, just battery status isnt show after convert...if someone can help me, i apreciate; thannks
gtr2converted.bin
(140.4 KiB) Downloaded 58 times
original 47mm.bin
(137.75 KiB) Downloaded 53 times
Has thanked: 436 times
Been thanked: 2137 times
As far as i know
if Conversion with the BIN converter GTR47mm to GTR2 some element it will not work
viewtopic.php?p=8843#p8843
in this case i think problem is element "circle scale" for battery is enable on GTR47mm BIN
after convert battery element may be not work but I am not sure because I don't have GTR2 long time ago.
so I can not test it , But if I'm not mistake "circle scale" battery element is cause this issue.
Please try this ( i am not sure it can fix you issue or not )
gtr2converted_remvoe_Circle_scale_Battery_packed.bin
(140.42 KiB) Downloaded 88 times
sfreud
Post by sfreud »
asoo wrote: 26 Apr 2022, 03:20
As far as i know
many thanks! its work now
