Two Requests for GTS 2 mini
slimreaper
Post by slimreaper »
Hello friends,
The watch faces I have given the links below belong to the Amazfit GTS and GTS 3
https://amazfitwatchfaces.com/gts/view/4459
https://amazfitwatchfaces.com/gts/view/8402
I'd like to adapt these watchfaces to the GTS 2 mini but I don't have the skills neither the knowledge to do so
I've already read the guide about watchfaces conversions and tried to do it myself but I couldn't figure it out in the end
So I'm kindly asking if any of you could migrate these watchfaces. If you could make them I'd be very grateful
Have a nice day :)
Has thanked: 441 times
Been thanked: 2142 times
- Not test on real device only test by Editor on web
- This is my last for GTS2mini for prove tool can make it.
viewtopic.php?p=12537#p12537
casiof91_GTS2Mini.bin
(570.6 KiB) Downloaded 47 times
Olavonix
Post by Olavonix »
Hello, could you explain to me how to convert these watch faces please?
Olavonix wrote: 23 Apr 2022, 03:10
- First you must be able to use program editor image. Because some time you must to edit on resize the image from other device in order to make it available to your device
- you must have resource (image) for make watchface on your device format
- you must have tool and program for editor watchface
you can see the tool and program editor for GTS2mini in this link :
- Take the time to experiment and understand what you want to do with it.
If you have all of these, you should probably be able to do it.
Another unpack for other device you can found it on the forum "watchface tool"
for unpack and bring the resource (image) for other device to make your watchface on your deivce
viewforum.php?f=29
