order of the layers
Posted: 08 Apr 2022, 19:43
hello I have made a watchface for the mi band 6 made with the software published here called "Mi Band 5 & 6 WatchFace Editor GUI" of @Johnson070 (viewtopic.php?t=1895), this is the right tool for my band 6? I have a problem in the order of the layers that show the functions of bluetooh and do not disturb, I leave the screenshot as I have tried several options directly from the json or from the status options and statussimplified and I can not get the blinds to be seen below the layer of the shadow of the bulb, that below the shutter must be the weather, because if I put the bluetooh option in the status section the weather notifications are above the shutter,
I also leave the images used ie:
above the bulb
below the blinds
final result
above the bulb
below the blinds
final result
