Please Help! Jeweler Raptor 2 for GTR2
- alexstam78
- Has thanked: 173 times
Hello to community and to creators, can anyone from creators port this amazing watchface exactly the same for GTR2. If it is possible please add bluetooth icon in the circle of moon phases because GTR2 don't support it and add weather, the down circle is for months and am, pm, 24h format. Unfortunately I don't have the ability and the skills to do it myself so I ask for help from here. Thanks to all creators. Thanks for hospitality. https://galaxystore.samsung.com/geardet ... lerRaptor2
- Has thanked: 419 times
- Been thanked: 2109 times
Please read carefully before download.- use images as far as can be used from image from original watchface
Note :
This watchface use system font to make the step font , If in the watch, it does not display like the preview image. And you want to modify it to meet your needs, please edit it yourself. because I don't have a GTR2 for test this element.
- alexstam78
Wow, thank you very much asoo, you did better than I imagined. It works ok and the steps shows like the preview which it's ok.
