watchfaces conversion from gtr2 to [GTR3]
Hi to everyone, I've tried to convert a watchface from gtr2 to gtr3 with some tool but I have bad result
, can someone help me and convert this gtr2 watchface for gtr3 (not pro) you can save me looot of time! I appreciate it! Thank you very much!
- Attachments
- d7ed4896529a1c1fb9acc8e4f4c0f5c4.bin
- (440.2 KiB) Downloaded 134 times
- Has thanked: 441 times
Robjovase81
Hi everyone, I dont know how to convert this WFs from GTR2 to GTR3, the same situation. Can anyone help with this? it will be much appreciate.
TIA
TIA
- Attachments
- brg_predator_orange_474447-a35b1d33db-30-302938-e815979f0b.bin
- (677.43 KiB) Downloaded 110 times
- brg_montecarlo-orange_faod_474447-a35b1d-302938-261445e662.bin
- (582.66 KiB) Downloaded 71 times
- brg_camo-khaki-v1.0-15485-42922ab4f-3029-302938-b9799f153a.bin
- (675.2 KiB) Downloaded 90 times
I have asked so many ppl on this site for conversion of these watch faces to GTR 3.
https://amazfitwatchfaces.com/gtr/view/11189
Will you kindly help with that or tell me how it can be done?
Thanks a lot on forehand.
Best regards
Best regards
Ilz wrote: 07 Apr 2023, 14:44Hello,
Best regards
as far as i know There is no program to convert GTR 47mm dial to GTR3.
If you want to create the aforementioned faces, you only need to unpack the GTR47mm faces you want and bring the image resource after youn unpack GT47mm to make a new GTR3 by use GTR3's editor.
You can see the tool about that in this link
viewforum.php?f=29
Note:
Recommended If you want to ask a question that is not related to the topic, it is recommended that you open a new topic on the topic you wish to ask.
Thank you so much for your reply!
God bless you!
I will try to see if I can get success
God bless you!
Hi.Ilz wrote: 07 Apr 2023, 18:01Thank you so much for your reply!
God bless you!
I will try to see if I can get success![]()
Did you manage to convert?
