Help with click shortcuts [GTR 3]
Inviato: 27 dic 2021, 12:30
Hello!
I've been playing around with a pipboy watchface.
Modified the index.js file to customize AOD and worked fine, then I wanted to add clicks (shortcuts) to heart, steps and weather data.
I copied the stanzas from another file that does that, modified the x and y axis and let the rest just about as it is.
The only click I got working is the weather, no matter where do I put my finger for the rest, it won't open heart nor steps.
I'll upload the zip file, could any of you give me a hand on this ?
