Page 1 of 1
G284 (GTR3) asoo for GTR2
Posted: 10 Dec 2021, 12:05
by alexstam78
Hello to community, can anyone from creators port this amazing watchaface exactly the same, only change PAI with pulse for GTR2? I post this because asoo stop make watchfaces for GTR2. Thank you very much to all creators and to asoo for his work.
https://amazfitwatchfaces.com/gtr/view/19920
Re: G284 (GTR3) asoo for GTR2
Posted: 10 Dec 2021, 18:17
by alik7676
I join the request
Posted: 14 Dec 2021, 17:30
by asoo
OK, probably no one does.
Let's just say, I will made it, but it might not be tested on a real device.
If the watch face there are any issue or want to change something , I ask that , please try to fix or modify it by yourself.
Posted: 15 Dec 2021, 05:45
by alexstam78
Thank you so much, asoo, I test it, everything works fine. Thank you again, Merry Christmas and happy New year.
Posted: 17 Dec 2021, 07:25
by alexstam78
I find one error, i have 39% battery and watchaface shows 50, please fix it because i don't have the skills to do it, thank you so much.
Posted: 17 Dec 2021, 09:15
by asoo
alexstam78 wrote: 17 Dec 2021, 07:25
May be happened but i am not sure I can not test because i do not have it.
Because using 10 images to show the approximate battery values as follows
This is an approximate value, it may be higher or lower. -+3-5%
1-10 = 10% 51-60 = 60%
11-20 = 20% 61-70 = 70%
21-30 = 30% 71-80 = 80%
31-40 = 40% 81-90 = 90%
41-50 = 50% 91-100 = 100%
I have already stated in the description.
Posted: 17 Dec 2021, 09:34
by alexstam78
Yes of course i see the description that's why I say this, because according to your description of the battery rates since I have a 39% battery it should say 40% and not 50%. You may have missed something between 30% and 40%, it you can see it and find something error you can repair it and upload here to test it.
Posted: 17 Dec 2021, 09:37
by asoo
alexstam78 wrote: 17 Dec 2021, 09:34
I have checked everything.
Using 10 images to display 100 levels and not knowing exactly how the watch is calculated. I thought I can only do like this.
The GTR3 doesn't display properly too. Most will be used only as a color bar in the show.
In the editor, it doesn't show same in clock too. So I can only do this.
Posted: 17 Dec 2021, 09:42
by alexstam78
Ok then probably you are right because now i have 38% and now shows 40 which is right and within the margins of error you mentioned. Thank you very much for the info, sorry and have a good day.
