Promised lunar phase on T-Rex Pro
Does anyone know something about the promised and non-functional feature of showing the lunar (moon) phase on the default or other watch faces with the current firmware of T-Rex Pro? Is it planned to implement the feature in one of the next updates? I mean, for me was it one of the features why I bought this watch.
Best regards
Nidhoegg
Nidhoegg
According a response on my email, Amazfit service center told me that they are aware of this bug and that they work on a bug fix for the next firmware release.
Best regards
Nidhoegg
Nidhoegg
Moon phase is finally back again. As promised it works on my watch with firmware 2.0.4.11 as of today!
Great job done, folks!
Best regards
Nidhoegg
Nidhoegg
spidercrab
- Has thanked: 27 times
- Been thanked: 3 times
I was very pleased to see this bug fix mentioned in the recent firmware 2.0.4.11 update. Out of interest, which WF are you using?
I would really like to add moonphase into some WF's but AFAIK there are no details about how the moonphase is implemented in the TrexPro WF.
I am using the default WF on my T-Rex Pro – the only one for now with a working moon phase. On the WF ’machine MOON 47MM’ for T-Rex, there is a wonderfull moon icon. If anyone could do such a WF with a working realistic moon icon - that would be brilliant!
Best regards
Nidhoegg
Nidhoegg
I use T-Rex Pro watchface editor v7.3 ,but still couldnt find a lunar phase feature, even not a location function for weather. i want to implement both to may wf. any information how to? many thanks!
Liquid4653
For the T-Rex Pro watchface editor, Weather is located on the edit page / Atmosphere tab, below Activity.
Sasha no longer develops that application so it is not going to get the lunar phase support I think.
It might be possible to manual add the moonphase if an official watchface was unpacked and the json was inspected, but I know of no official unpacked watchfaces.
In case it helps;)
Für den T-Rex Pro-Zifferblatt-Editor befindet sich das Wetter auf der Bearbeitungsseite / Registerkarte „Atmosphäre“ unter „Aktivität“.
Sasha entwickelt diese Anwendung nicht mehr, also wird sie meiner Meinung nach nicht die Mondphasenunterstützung bekommen.
Es ist möglicherweise möglich, die Mondphase manuell hinzuzufügen, wenn ein offizielles Watchface entpackt und der Json überprüft wurde, aber ich kenne keine offiziellen entpackten Watchfaces.
In case it helps;)
