Display image instead of SECONDS
I created a simple BIP watchface and I wanted to make a "walking Mario".
The idea was to create it instead of "SECONDS ONES".
I'm using these tools:
- amazfitbiptools.1.0.3.1
- amazfit bip wf editor ilgruppotester v1024
The watchface shows up correctly in these tools but it doesn't work when uploaded to my BIP.
The problem is that the lower half of the mario picture is static, and the botom is "moving" but it cuts the rest of the line along from left to right of the BIP display.
Any suggestions to make it working?
Here is the link to my WF: Mario walk TEST
savethedinosaurs
I've been trying to figure out simple animations with seconds too, and I have a few theories. If anyone knows more details or has corrections please comment:
1) There seems to be a pixel size limit vertically. Something like 40 pixels tall max, but I haven't tested this fully. (* * * EDIT: It's 24 pixels max for height, info via TXK below * * *)
2) You need to use both Seconds 'ones' and 'tens' and they need to be on the same horizontal lines (same Y value). You can use blank/transparent images for the 'tens' if you don't want it to display anything, but without the tens present the pixels won't update for either one. And it only updates along the Y lines that the tens occupy. (horizontally)
3) Like you said, it looks like it affects the full lines left/right, and it depends on the 'tens' Y position. Also it is only within that 40 pixel height.
4) It was mentioned in another thread that using seconds will drain the Bip battery faster because it runs all the code every second rather than only every minute :\
By the way, both of the wf editors have some issues that don't match up exactly with the Bip. For example, the ilgruppotester editor will give 'invalid code' errors preventing you from doing some things that the Bip can actually do. The Vlack editor also has some quirks like it shows some depth-sorting in the opposite way the Bip does (Activities). So try both editors if you run into problems.
Thank You for Your answer.
1) Pixel size limit vertically - I thought about it also, but as You can see from my WF, the picture that I try to "make it move" it's 32x30 pixels.
2) About using both "tens" and "ones" - I also figured out that without using tens, the ones won't display at all.
As for a blank "tens" - I uploaded a new version in which I made a transparent png of 32x30 pixels and I put it in the same XY as the "ones" - no success at all.
4) About battery - to be honest, at this point I don't care
I'd just like to make it work, and than we'll see how does it affect battery life
Regarding the WF editors - yeah, I can see that the ilgruppotester editor has some bugs but I'm not that much into it to find out which bugs there are present. The same goes for the v1ack editor.
If You figure the solution to this problem please let me know.
Thank You once again
TXK wrote: 20 Nov 2018, 01:12"Image for the seconds digits, height can not exceed 24 pixels. If it exceeds 24 pixels, it will be cut by the watch system。"
It makes sense... I'll try that one later today.
It comes to my mind that it must have something to do with the slow refresh rate of the BIP
Can You tell me where You got that "24 pixels limit" info from? Any specification guide or something like that?
savethedinosaurs
Thanks TXK. It's too bad it's such a small size. We can use that for animating parts of images, i guess. You could make Mario the original 1:1 pixel size, though it'll be pretty small.
Yeah BIP documentation would be really great to have!
savethedinosaurs
I wonder if it's possible to modify the firmware and increase the size limit.
- TXK
- Has thanked: 150 times
- Been thanked: 99 times
Not only the height limit, but also the following restrictions:savethedinosaurs wrote: 20 Nov 2018, 10:49I wonder if it's possible to modify the firmware and increase the size limit.
The whole row of seconds'digital height (from left to right), will be forced to clear all images, icons and watch pointers except the time number and background image.
Ten-digit and one-digit numbers of seconds must be on the same line, and two types must exist at the same time in order to work.
This is the result of my own test.
Ah, yes, that BIP documentation would be nice to have indeed...savethedinosaurs wrote: 20 Nov 2018, 09:02Thanks TXK. It's too bad it's such a small size. We can use that for animating parts of images, i guess. You could make Mario the original 1:1 pixel size, though it'll be pretty small.Yeah BIP documentation would be really great to have!
About Mario... even that original Mario image is exactly 32x30 pixels xD
limaalfa11
I am searching for somebody who can create for me watchface and help me to implement that to stratos. I know how it should look exactly - i have a picture. it's very simple design but the main problem is that instead of second i want to have figure, statue there, as on the picture. Do any one of you know if that is possible? Can anyone help me with this? Of course I can pay for that:) it's my dream to have like that watch
- TXK
Https://amazfitwatchfaces.com/bip/view/21915
Sorry, the number in seconds is still not supported to be higher than 24 pixels.
However, you can use the second pointer to refresh the large number of seconds.
I tested the last firmware (firmware 1.1.5.16) it's still show seconds image on the watchface only 24 pix.TXK wrote: 19 Mar 2019, 09:18Https://amazfitwatchfaces.com/bip/view/21915
The latest firmware version of the watch supports the seconds of the larger picture (the height of the picture can exceed 24 pixels)
This watchFace can show the seconds in larger image because the maker use analog seconds to refresh screen.
Normally, the seconds image is on the screen according to the actual size but will display on the watchface only 24 pix.
But every time when the screen was refresh the seconds image will show full image
code ( Https://amazfitwatchfaces.com/bip/view/21915 )
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Time": {
"Hours": {
"Tens": {
"X": 107,
"Y": 47,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 135,
"Y": 47,
"ImageIndex": 1,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 107,
"Y": 96,
"ImageIndex": 11,
"ImagesCount": 10
"Ones": {
"X": 127,
"Y": 96,
"ImageIndex": 11,
"ImagesCount": 10
"Seconds": {
"Tens": {
"X": 165,
"Y": 0,
"ImageIndex": 21,
"ImagesCount": 10
"Ones": {
"X": 0,
"Y": 0,
"ImageIndex": 31,
"ImagesCount": 10
"AmPm": {
"X": 162,
"Y": 64,
"ImageIndexAm": 22,
"ImageIndexPm": 23
"Activity": {
"Steps": {
"TopLeftX": 140,
"TopLeftY": 154,
"BottomRightX": 182,
"BottomRightY": 163,
"Alignment": "TopLeft",
"Spacing": 2,
"ImageIndex": 41,
"ImagesCount": 10
"Pulse": {
"TopLeftX": 140,
"TopLeftY": 138,
"BottomRightX": 164,
"BottomRightY": 147,
"Spacing": 2,
"ImageIndex": 41,
"ImagesCount": 10
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 126,
"TopLeftY": 7,
"BottomRightX": 141,
"BottomRightY": 16,
"Spacing": 2,
"ImageIndex": 51,
"ImagesCount": 10
"Day": {
"TopLeftX": 151,
"TopLeftY": 7,
"BottomRightX": 166,
"BottomRightY": 16,
"Spacing": 2,
"ImageIndex": 51,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 112,
"Y": 20,
"ImageIndex": 61,
"ImagesCount": 7
"Battery": {
"Icon": {
"X": 112,
"Y": 145,
"ImageIndex": 68,
"ImagesCount": 6
"AnalogDialFace": {
"Seconds": {
"OnlyBorder": false,
"Color": "0xFFFFFF",
"Center": {
"X": 56,
"Y": 111
"Shape": [
"X": -3,
"Y": -3
"X": 1,
"Y": -4
"X": 2,
"Y": 3
"X": -3,
"Y": 2
"X": -3,
"Y": -1
My test use "seconds one" + "analog seconds" to show seconds image over 24 Pix https://amazfitwatchfaces.com/bip/view/10598
- TXK
romstemp wrote: 20 Mar 2019, 02:55I tested the last firmware (firmware 1.1.5.16) it's still show seconds image on the watchface only 24 pix.TXK wrote: 19 Mar 2019, 09:18Https://amazfitwatchfaces.com/bip/view/21915
code ( Https://amazfitwatchfaces.com/bip/view/21915 )-----------------------------------------------------------------------------------------------------------------Code: Select all
{ "Background": { "Image": { "X": 0, "Y": 0, "ImageIndex": 0 } }, "Time": { "Hours": { "Tens": { "X": 107, "Y": 47, "ImageIndex": 1, "ImagesCount": 10 }, "Ones": { "X": 135, "Y": 47, "ImageIndex": 1, "ImagesCount": 10 } }, "Minutes": { "Tens": { "X": 107, "Y": 96, "ImageIndex": 11, "ImagesCount": 10 }, "Ones": { "X": 127, "Y": 96, "ImageIndex": 11, "ImagesCount": 10 } }, "Seconds": { "Tens": { "X": 165, "Y": 0, "ImageIndex": 21, "ImagesCount": 10 }, "Ones": { "X": 0, "Y": 0, "ImageIndex": 31, "ImagesCount": 10 } }, "AmPm": { "X": 162, "Y": 64, "ImageIndexAm": 22, "ImageIndexPm": 23 } }, "Activity": { "Steps": { "TopLeftX": 140, "TopLeftY": 154, "BottomRightX": 182, "BottomRightY": 163, "Alignment": "TopLeft", "Spacing": 2, "ImageIndex": 41, "ImagesCount": 10 }, "Pulse": { "TopLeftX": 140, "TopLeftY": 138, "BottomRightX": 164, "BottomRightY": 147, "Alignment": "TopLeft", "Spacing": 2, "ImageIndex": 41, "ImagesCount": 10 } }, "Date": { "MonthAndDay": { "Separate": { "Month": { "TopLeftX": 126, "TopLeftY": 7, "BottomRightX": 141, "BottomRightY": 16, "Alignment": "TopLeft", "Spacing": 2, "ImageIndex": 51, "ImagesCount": 10 }, "Day": { "TopLeftX": 151, "TopLeftY": 7, "BottomRightX": 166, "BottomRightY": 16, "Alignment": "TopLeft", "Spacing": 2, "ImageIndex": 51, "ImagesCount": 10 } }, "TwoDigitsMonth": true, "TwoDigitsDay": true }, "WeekDay": { "X": 112, "Y": 20, "ImageIndex": 61, "ImagesCount": 7 } }, "Battery": { "Icon": { "X": 112, "Y": 145, "ImageIndex": 68, "ImagesCount": 6 } }, "AnalogDialFace": { "Seconds": { "OnlyBorder": false, "Color": "0xFFFFFF", "Center": { "X": 56, "Y": 111 }, "Shape": [ { "X": -3, "Y": -3 }, { "X": 1, "Y": -4 }, { "X": 2, "Y": 3 }, { "X": -3, "Y": 2 }, { "X": -3, "Y": -1 } ] } } }
However, you can use the second hand to refresh the large number of seconds.
