Page 1 of 2
Haylou Solar Watchface Tool
Posted: 02 Mar 2021, 12:23
by osmat
Simple tool to pack and unpack .bin watchfaces for Haylou Solar
Important! To run this application, you also need installed .NET 5.0 Runtime.
WatchFace Tool Basic Tutorial for Haylou Solar
Re: Haylou Solar Watchface Tool
Posted: 03 Mar 2021, 07:33
by DedsecSD
Can i set custom watch dial for imilab kw66 using haylou solar watch faces
Posted: 03 Mar 2021, 09:24
by osmat
DedsecSD wrote: 03 Mar 2021, 07:33
yes you can
Posted: 03 Mar 2021, 23:09
by Deel
Hi, can i use solar watchface for à "mibro air" , it use. bin files too, but use a . json and. dat in a zip files for the watchfaces.
Thanks for your answer.
Posted: 05 Mar 2021, 11:20
by osmat
Deel wrote: 03 Mar 2021, 23:09
not
Posted: 14 Mar 2021, 16:09
by worktgr
thanks for this great tool
Posted: 17 Mar 2021, 00:49
by PozNashu
Nice tool, thank you!!!I just start to make my first watch face for my Solar LS05.
Posted: 25 Mar 2021, 11:03
by worktgr
Hope for an update to this tool.
Problems I found
- weather and temperature not sync, maybe it's firmware problem
- icon steps animation doesn't run smoothly
Is it possible to arrange the order of element which one is at the front, example hours and minutes in front of connection.
Posted: 31 Mar 2021, 14:50
by KYR Watchfaces
worktgr wrote: 25 Mar 2021, 11:03
Problems I found
I think @osmat is not the developer of the tool, so he will not solve this problems.
The website for the tool, where you can find the e-mail of the developer to report bugs or send suggestions, is
http://hswt.tilda.ws/
Posted: 04 Apr 2021, 00:24
by worktgr
KYR Watchfaces wrote: 31 Mar 2021, 14:50
Problems I found
I saw it. New version 1. 1 is available to use after donation
Posted: 15 Apr 2021, 05:52
by Krzysieq
how many $$ i must donate to v 1.1?
Posted: 16 Jun 2021, 06:04
by nick_fox123
Excuse me, I have a request. Can you share the new tool with me for free, v1.1
Posted: 16 Jun 2021, 09:59
by GIK-Team
nick_fox123 wrote: 16 Jun 2021, 06:04
https://amazfitwatchfaces.com/external/56
Posted: 16 Jun 2021, 13:40
by nick_fox123
Posted: 25 Jun 2021, 15:23
by stevelbhui
how to use animation speed?
Posted: 23 Aug 2021, 09:57
by BIGGBOSS
Can I use Haylou Solar Watchfaces in Haylou RT LS05S ?? Experts plz Guide..!!
Posted: 31 Aug 2021, 06:26
by Aych38
Hello haylou için saat türkçe nasıl yapabilirim rt ls05s saati
Posted: 02 Sep 2021, 23:29
by kmzdotnet
stevelbhui wrote: 25 Jun 2021, 15:23
Actually it is FRAME DURATION, the calling "animation speed" is not suitable in this case. So if you set 1000, then each image in the animated element will displayed 1 second long. Just like the timeline in Adobe Photoshop.
Posted: 03 Sep 2021, 16:07
by Aych38
Merhaba haylou rt ls05s için tema var mi
Posted: 03 Sep 2021, 16:08
by Aych38
Lütfen yardım haylou ls05 temaları haylou rt ls05s nasıl yükleye bilirim
Posted: 13 Sep 2021, 20:28
by Sinaebz
Hi. Please made tools for create HAYLOU RS3 watchface. Please
Posted: 24 Oct 2021, 00:52
by nick_fox123
hi, it is a great tool , can it support haylou
rs3 watch?
Posted: 26 Nov 2021, 15:14
by alihaider4670
osmat wrote: 03 Mar 2021, 09:24
yes you can
Hello sir,
Hope u have a bright day i just wanted to ask that will the Haylou Faces work on LS05s or is it just LSO5.
p.s : if i have file manager on Android 11 will the faces still work?
Posted: 26 Nov 2021, 15:52
by osmat
alihaider4670 wrote: 26 Nov 2021, 15:14
yes you can
Hello sir,
We have no such information. You can write a tool for the author to add your watch model
Posted: 06 Apr 2022, 20:17
by Noe156
How can you create a watch face with .tbwf format? Is there a tool like the one used for files with a .bin extension?
