Page 1 of 1
dev.huami.com Integrate with Watch Face Greyed-Out
Posted: 18 Feb 2021, 16:32
by Rcappa
Hey Everyone,
I have been approved as a Huami Developer, but when I go to the "integrate with Watch Face" link, it's grey-out. Anyone know what I am missing?
Thanks in advance.
Re: dev.huami.com Integrate with Watch Face Greyed-Out
Posted: 19 Feb 2021, 00:55
by asoo
Rcappa wrote: 18 Feb 2021, 16:32
Hey Everyone,
Thanks in advance.
If you have been approved as a huami Dev. and you can not click " integrate with ..........". You can try to direct to the page with this url (
https://dev.huami.com/#/watch-skins/ )
Posted: 19 Feb 2021, 02:00
by Rcappa
Thanks Asoo. That worked!! I appreciate it!
Posted: 19 Feb 2021, 12:11
by demiurg1
Thank you Asoo. For me, the link turned out to be effective too! You helped a lot. Greetings.
Posted: 22 Feb 2021, 06:59
by eliasf
Does anyone know how to edit the .zip file you get from the huami service when you export from their website?
It is empty in file explorer, I tried changing the extension to .bin and have a go at it with the beta py amazfit tool but that didn't work.
Any ideas?
Posted: 22 Feb 2021, 10:37
by asoo
eliasf wrote: 22 Feb 2021, 06:59
unzip file with Winzip or WinRAR ( when you "unzip" you can found .bin )
I don't understand what do you mean "It is empty in file explorer"
.zip you receive from huami is a zip compress you must to extract before use.
Posted: 22 Feb 2021, 22:50
by eliasf
Stupidly I wasn't using a program as nowadays windows file explorer handles everything I've come across but in this case the zipped folder was showing empty.
It worked as soon as I installed 7-zip.
Thanks asoo!
Posted: 15 Mar 2021, 16:23
by demiurg1
asoo wrote: 19 Feb 2021, 00:55
Hey Everyone,
Thanks in advance.
After logging in to the "Huami Open Platform", I used this link without any problems. I have edited a few watch faces via the website. It has been so until today. The link has stopped working. On the Huami website, I also do not have access to the editing tool (gray highlight). Do you have any idea to solve my problem?
Greetings.
P.S.
I really care about having access to this online editor. I have a couple of watch faces there.
Posted: 15 Mar 2021, 19:21
by Rcappa
Same here, when I go to the link, it just sends me back to the homepage dev.huami.com. Is there are new url address anyone?
Posted: 01 May 2021, 01:44
by ayushpsc
