Android 11
paulomodesto
Android 11
Post by paulomodesto »
I have an Xiaomi MI 10 device and all was working good until I have updated to Android 11.
Now I can't use Amazfaces app to install new watchfaces.
I saw somewhere that on Android 11 Google have disabled to other apps to access read and write other apps folders in "Android-Data directory.
Is there a way to fix this behavior or i just have to uninstall the Amazfaces app and stick with Zepp own watchfaces?
paulomodesto
I managed to fix it by uninstall and installed it again and changing the installation method for direct instal by AmazFaces app, but there's some watchfaces that I can't apply it gives error.
When installing an watchface i can't do nothing with the smartphone like read an sms or seeing an email because it gives error installing the watchface, we have to wait until it reaches the end of the entire process, which is boring for some watchfaces that takes long minutes to apply.
Stas
Been thanked: 34 times
Post by Stas »
Thank you for replay, in the next update we try fix it
paulomodesto wrote: 11 Dec 2020, 03:26
