Page 1 of 1
GTR_Watch_face.exe doesnt unpack bin files
Posted: 05 Oct 2020, 13:07
by Shild
Hello. I wanted to recolor this
https://amazfitwatchfaces.com/gtr/view/8903 in orange, so i downloaded GTR_Watch_face.exe but when i click on Unpack bin and select the bin file i donwloaded, nothing happens.
I have tried with some other bin files, even the compressed ones. I would appreciate if someone can tell me how make it work
Re: GTR_Watch_face.exe doesnt unpack bin files
Posted: 05 Oct 2020, 13:31
by Shild
This is what happens when i try Unpack bin/Unpack compressed bin
Please dont take it as a spam, i dont have a youtube channel and i dont want any subscribers
Posted: 05 Oct 2020, 16:46
by asoo
File is compress bin , you must use unpack compress bin to do that file.
Posted: 05 Oct 2020, 16:51
by Shild
asoo wrote: 05 Oct 2020, 16:46
Thank you for your answer, but as u can see in the video it doesn't work even with "unpack compress bin"
https://www.youtu --- be.com/watch?v=-GfEI_OIlTM
Posted: 05 Oct 2020, 17:03
by asoo
Shild wrote: 05 Oct 2020, 16:51
You can try the new version : 8.5
viewtopic.php?p=3789#p3789
PS,
The program path should not contain spaces
it is recommended to place the program in the root directory of the disk
Please check your folder name have a space or not ?
Posted: 05 Oct 2020, 17:26
by Shild
asoo wrote: 05 Oct 2020, 17:03
PS,
Yes my folder had a space in its name, now it works! Thank you so much!
Posted: 05 Oct 2020, 19:25
by Shild
And i just finished the recolor! Again, many thanks
