GTR_Watch_face.exe doesnt unpack bin files
Hello. I wanted to recolor this https://amazfitwatchfaces.com/gtr/view/8903 in orange, so i downloaded GTR_Watch_face.exe but when i click on Unpack bin and select the bin file i donwloaded, nothing happens.
I have tried with some other bin files, even the compressed ones. I would appreciate if someone can tell me how make it work
This is what happens when i try Unpack bin/Unpack compressed bin
Please dont take it as a spam, i dont have a youtube channel and i dont want any subscribers
- Has thanked: 411 times
- Been thanked: 2048 times
File is compress bin , you must use unpack compress bin to do that file.
Thank you for your answer, but as u can see in the video it doesn't work even with "unpack compress bin"asoo wrote: 05 Oct 2020, 16:46File is compress bin , you must use unpack compress bin to do that file.
https://www.youtu --- be.com/watch?v=-GfEI_OIlTM
You can try the new version : 8.5Shild wrote: 05 Oct 2020, 16:51Thank you for your answer, but as u can see in the video it doesn't work even with "unpack compress bin"asoo wrote: 05 Oct 2020, 16:46File is compress bin , you must use unpack compress bin to do that file.
viewtopic.php?p=3789#p3789
PS,
The program path should not contain spaces
it is recommended to place the program in the root directory of the disk
Please check your folder name have a space or not ?
Yes my folder had a space in its name, now it works! Thank you so much!asoo wrote: 05 Oct 2020, 17:03You can try the new version : 8.5Shild wrote: 05 Oct 2020, 16:51Thank you for your answer, but as u can see in the video it doesn't work even with "unpack compress bin"asoo wrote: 05 Oct 2020, 16:46File is compress bin , you must use unpack compress bin to do that file.
PS,
