Pagina 1 di 1
Diretorio WfzMaker
Inviato: 18 giu 2020, 01:36
da fariajlopes
Boa Noite!
Quando da criação do Watchface no WFZMaker?
Não consigo visualizar diretorio de salvamento....
Após a criação em qual diretorio a mesma é salva????
Ou estou fazendo errado????
Good evening!
When creating Watchface in WFZMaker?
I can't see the rescue directory ....
After creation in which directory is it saved ????
Or am I doing it wrong ????
Re: Diretorio WfzMaker
Inviato: 20 giu 2020, 01:43
da TXK
fariajlopes ha scritto: 18 giu 2020, 01:36
Boa Noite!
Good evening!
Operation guide
How to assemble your favorite dial
1. Download your favorite dial numbers and hand pointers:
https://amazfitwatchfaces.com/pace/view/6467
https://amazfitwatchfaces.com/pace/view/6287
2. Open the dial you downloaded with zip APP, and extract it into a separate folder
- 10.png (123.52 KiB) Visto 1462 volte
- 1.png (108.55 KiB) Visto 1467 volte
3. Create a new dial with wfzmaker (or open an existing dial for modification)
- 2.png (70.54 KiB) Visto 1467 volte
4. Click on the following items to find your unzipped dial folder and find your favorite dial hand pointers and numbers
- 3.png (85.04 KiB) Visto 1467 volte
- 4.png (142.55 KiB) Visto 1467 volte
- 11.png (324.99 KiB) Visto 1461 volte
5.Move, add and delete functions on the dial
- 5.png (129.61 KiB) Visto 1467 volte
- 7.png (88.4 KiB) Visto 1467 volte
- 8.png (63.28 KiB) Visto 1467 volte
6. Click
[Export] item. Find the location folder you want to store, write down the file name, and make sure to
[save].
- 9.png (162.42 KiB) Visto 1467 volte
Inviato: 21 giu 2020, 03:34
da fariajlopes
thank you
