Bip V1.1.6.48 firmware fonts AWFUL!
CarsonGrey
Post by CarsonGrey »
So, on a whim I updated MiFit Android to whatever the latest is, and at the next sync the watch firmware updates. I normal avoid using the App and use only GadgetBridge, and if I know I might need faster GPS sync for a coming run.
Nothing seems to have changed except they've ruined the font. It's now a hideous fixed-width one that looks like something from X-Windows in the 90s.
Even with a fixed width it still manages to wrap and line break worse! Letters cut in half, bottom row of pixels missing. Nothing about it is better. In fact it looks like a straight-up mistake.
Is anyone else seeing this font with .48? Is there a way to revert it?
Has thanked: 128 times
Been thanked: 19 times
Post by taw_bip »
You posted this in the GTR, not the Bip, forum.
GaryM
Post by GaryM »
Yes I'm on V48 and the fonts are hideous. I used gadgetbridge to update to the larger fonts here in another thread but once you pair up with the Mi Fit apps it updates and reverts back to the smaller font.
Either stay with gadgetbridge to keep the large fonts and loose the GPS or use the MI Fit app and use the hideous fonts keeping the GPS.
TMWNN
Post by TMWNN »
BOLD_v6.15_9_spec.ft.zip is compatible with 1.1.6.48.
GaryM
Post by GaryM »
TMWNN wrote: 28 May 2020, 12:32
Yes it does but reverts back one you use the Mi Fit app so it's useless.
TMWNN
Post by TMWNN »
As I said, the font is compatible with 1.1.6.48. Try it.
PDX_GEEK
Post by PDX_GEEK »
Where do I find the BOLD_v6.15_9_spec.ft.zip file to download?
