How to install watchfaces (Pace, Stratos, Verge)
Has thanked: 1166 times
Been thanked: 279 times
Detailed instructions for installing custom watch faces on Amazfit Verge, Stratos, Pace watches.
For a successful installation, you need to connect your watch to PC or Mac using a native charging docking station.
There are two types of watch faces for these smartwatches:
.WFZ and .APK
Installing .WFZ watch faces format via PC
  1. Connect the smartwatch to your PC.
  2. Make sure you have all the drivers installed.
  3. After connection, the internal memory of the device will be available to you. Browse to the WatchFace folder.
  4. Put there all the watch faces that you would like to set on the watch.
  5. Disconnect the device from your PC.
  6. Now the watch faces will be available for installation in the watch's menu or the Amazfit application.
Note! Amazfit app on iPhone does not display previews of third-party watch faces.
Setting .WFZ watch faces format via Mac
  1. Connect the smartwatch to your Mac.
  2. Make sure you have Android File Transfer installed.
  4. Put in the WatchFace folder all the watch faces that you would like to set on the watch.
  5. Disconnect the device from your Mac.
Installing .APK watch faces format via PC
  3. Use one of the following programs:
  4. If you have ADB (SDK Platform Tools) installed, you can use: adb install <packagename> command
    Example: adb install LCD_BW_Digital_MZI_v0.4_Verge_5b60d41446581_01082018.apk
    Watch this video instruction on how to install watch faces via APK Installer:
Installing .APK watch faces format via Mac
  2. Download and unzip the SDK Platform:
  3. If you have ADB (SDK Platform Tools) installed, you can use: adb install <packagename> command
    Image Image Image Image
  4. Disconnect the device from your Mac.
  5. Now the watch faces will be available for installation in the watch's menu or the Amazfit application.
Uninstalling APK package
If you have ADB (SDK Platform Tools) installed, you can use command: adb install <packagename>
Example: adb uninstall com.marekzima.DigitalEssentials
Note! Package names can be found on each watch-face description!
You may also use our application or others, such as Amazmod, to install watch faces.
This manual is current at the time of writing.
If you notice any inaccuracies or mistakes, please, let us know
