GTS Notifications and Alarms
Posted: 27 Jan 2020, 13:52
HI I had a Bip and upgraded to the GTS, with the Bip you could go back through the notification and re-read them can you do this on the GTS. I just got a messenger notification and to re-read it I went into notifications and it's empty!
Another thing if I set a custom alarm time say 21:59 as I did either on the GTS or on the Amazfit app after a few mins they disappear and all the alarms go back to the factory set ones is there any way around this?
Paul
Paul
