HI I had a Bip and upgraded to the GTS, with the Bip you could go back through the notification and re-read them can you do this on the GTS. I just got a messenger notification and to re-read it I went into notifications and it's empty!
Another thing if I set a custom alarm time say 21:59 as I did either on the GTS or on the Amazfit app after a few mins they disappear and all the alarms go back to the factory set ones is there any way around this?
Paul
GTS Notifications and Alarms
Hello! I have the same problem with Amazfit GTR. The alarms disappear apparently randomly, within a few hours to a day. Very unreliable and frustrating. Did you find any solutions the problem?
I just realized this could be because I'm also using the unofficial tools app. It might override the alarm settings. I now tried to disable alarms in that app, let's see if it helps.
