Pulse & Steps Won't Display
Kylevski
Post by Kylevski »
I've been trying to get the steps and pulse to display on the background, but they keep disappearing in the preview. Everything looks fine in WF Editor, but they disappear after it packs the bin.
Here is what it looks like before I create the bin (remove the space before .cc - Who da think "Add image to post" would be blocked by it's own site? :? )
i.postimg .cc/ryQvBxXM/Neg1.png
Now, this is what it looks like on the preview and watch (remove the space before .cc)
i.postimg .cc/sgSHgZ8B/Negative-packed-static.png
I've attached the JSON file incase that helps see what I'm doing wrong. Had to change the extension to txt since someone thought it was a good idea to block JSON files on a board for watchface support. :roll:
Negative.txt
(2.12 KiB) Downloaded 48 times
Been thanked: 2120 times
You don't send BIN to test . so I make my pictures and test it on your json Code
B-test_packed.bin
(5.9 KiB) Downloaded 82 times
I think issue is code in line "ImagesCount"
if your count set 1 it 's will show only 0130.png ( number 0 ) so if your number is not 0 the screen may be empty or black
Your code
"Activity": {
"Steps": {
"TopLeftX": 152,
"TopLeftY": 9,
"Spacing": 1,
"ImagesCount": 1,
"BottomRightY": 22,
"BottomRightX": 163,
"ImageIndex": 130,
"Alignment": "TopLeft"
"Pulse": {
"TopLeftX": 151,
"TopLeftY": 43,
"Spacing": 1,
"ImagesCount": 1,
"BottomRightY": 56,
"BottomRightX": 162,
"ImageIndex": 130,
Edited "ImagesCount": 10, ( change 1 to 10)
"Activity": {
"Steps": {
"TopLeftX": 152,
"TopLeftY": 9,
"Spacing": 1,
"ImagesCount": 10,
"BottomRightY": 22,
"ImageIndex": 130,
"Pulse": {
"TopLeftX": 151,
"TopLeftY": 43,
"Spacing": 1,
"ImagesCount": 10,
"BottomRightY": 56,
"ImageIndex": 130,
I am not sure 100% for this issue.
Because I don't have your BIN
Kylevski
Post by Kylevski »
Thanks so much [mention]asoo[/mention]! That did the trick. I thought I changed that earlier, but I guess WF Editor didn't save it to the JSON.
