Unable to replace the (big?) fresh clock faces (ie: Nixie) pls help!!!
Inviato: 05 gen 2020, 12:24
Hi Guys
pls help me I dont understand ... first of all until today any watchface loaded without problem, now Im unable to load two faces (for the moment), like Nixie Watch https://amazfitwatchfaces.com/verge-lite/view/592 (I love it a lot!! I want it!!!
or, just for a test, Star Wars clock https://amazfitwatchfaces.com/verge-lite/view/576
Thats because are really big?
Sync is good (but takes a lot, 9' or more, a little bit...) but the face is not present.
Please note, before bother you all
, I have done these steps:
- Verge Lite resetted;
- uninstalled and reinstalled bot AmazFit and your app;
- cleaned Android\data\com.huami.watch.hmwatchmanager\files\watch_skin_local;
- re-installed and re-synced all the stock faces thru AmazFit;
- just in case: in Android\data\com.huami.watch.hmwatchmanager\files\watch_skin_local manually renamed and replaced the face using a PC;
- just in case: changed the local (phone and clock) from italian to english;
Stranger Things:
- from your App file is copyed correctly, for example, replacing first stock face (51832854d20fee8490feea7634c6ab4f) the .bin file is 504KB now, replacing by Nixie, is 1350KB;
- other fresh files in between loads correctly (like Illuminator - VL https://amazfitwatchfaces.com/verge-lite/view/591
no way: if I replace one or more of the 14 faces with Nixie (pls!pls!) face is not present (same for Star Wars): Verge Lite contains only the usual two (huge) default faces, third is not present, I have the stupid suspect faces too big are not loaded (however AmazFit says "sync succesfull") because of my slow bluetooth (maybe,I dont know, usually I'm on 3, max 4 minutes to sync any face), its normal TEN minutes to sync?
For your info I'm using firmware v.1.3.4.06 and the latest version of AmazFit and your app.
Any idea please? I love Nixie!! (a lot of thanks to the author).
Thanks in advance and sorry my english.
Giovanni
Stranger Things:
Giovanni
