Página 4 de 7
py amazfit tool
Enviado: 17 Ago 2019, 20:13
por afwafwafw
what is...
- can pack/unpack .bin file for amazfit verge lite/gtr(original watchfaces)
what isn't...
- 100% compatibility with amazfit_bip_tool
- 100% compatibility with .json structures of bip
requirements
- python3(tested on 3.7.4)
- pillow(tested on 6.1.0)
Código: Selecionar todos
## usage
* for verge lite
* see scripts folder
* to unpack
* to pack
* to pack
* to unpack
* for GTR
* to unpack
* to pack
* to pack
* to unpack
Re: py amazfit tool
Enviado: 25 Nov 2019, 19:25
por Pinkabou
Did you have a GTS version ?
I try your soft but have a error. My .Bin file is a GTS watchFace
Re: py amazfit tool
Enviado: 26 Nov 2019, 16:58
por ajs
Horatius80 escreveu: 11 Nov 2019, 16:49
HI I do not know how to contact lolyinseo directly, but in his last dev-gtr the battery scale is not working...
I wrote to him about this problem, if there is any answer. I’ll let you know, or maybe he will write it himself.
Re: py amazfit tool
Enviado: 27 Nov 2019, 05:39
por Horatius80
It is OK, I've already figured it out. There are syntax differences in the *.json between GTR and DEV-GTR version .. that was the problem ... here is watchface that works as I wanted
https://amazfitwatchfaces.com/gtr/view/2040
Re: py amazfit tool
Enviado: 29 Nov 2019, 08:21
por H078
Any recommendations on how to keep .bin under 2Mb?
I was making digital watch and size of .bin file kept increasing eventhough all images put together are at most 500kb.
Re: py amazfit tool
Enviado: 01 Dez 2019, 13:16
por hikashi
Any plans to port in hearts and linear scale i.e. segments? I tried to port in with new elements using the c# as reference but to no avail.
Im not too sure what is the equivalent of list<xy> to python.
Re: py amazfit tool
Enviado: 03 Dez 2019, 15:46
por pacomar
H078 escreveu: 29 Nov 2019, 08:21
reducing the number and size in pixels of png files.
Re: py amazfit tool
Enviado: 04 Dez 2019, 17:31
por Horatius80
pacomar escreveu: 03 Dez 2019, 15:46
Or do not use antialiasing to prevent occurrence of semitransparent and partially transparent pixels, reduce the number of colors per image, color palette has to be RGB and using maximal PNG compression ...
Re: py amazfit tool
Enviado: 04 Dez 2019, 18:42
por dpassaggio
Hi guys, I just tried the Gts version of this tools in python, but I find myself with the same error I had with the gtr version, or following the whole unpack guide, I get the following error
File "main.py", line 4, in <module>
from watchFaceParser.config import Config
ImportError: No module named watchFaceParser.config
how do I fix it?
Re: py amazfit tool
Enviado: 09 Dez 2019, 09:28
por DJArty
dpassaggio escreveu: 04 Dez 2019, 18:42
.. same error
+1 have same error (Ubuntu 16.04 x64)
P.S. but maybe its because default "python main.." starts python ver 2.7 so may be just need start like "python3 main ..."
P.P.S. Yes need start
and pillow 6+ for python3.7
Re: py amazfit tool
Enviado: 10 Dez 2019, 00:52
por hikashi
500kb is too big
> Reuse asset i.e. same 'number' asset for different element like date, activity
> Use assets with smaller dimension
> Use 266 pixel size for the 0001 preview asset
Cheers!
Re: py amazfit tool
Enviado: 18 Dez 2019, 03:51
por Luizneto100
I'm new, help me, because every time I pack, the bin comes out with a different color from the original? Ex: Green color dial; Installed: Turns Red.
Re: py amazfit tool
Enviado: 18 Dez 2019, 16:25
por H078
What are acceptable transparecy levels for .png files? I tried 32bit and anything lower than that tool throws an error in a log file " invalid transparecy mask".
32bit transparecy generally increases file size in kb.
Re: py amazfit tool
Enviado: 18 Dez 2019, 17:25
por schwedenpaule
hikashi escreveu: 10 Dez 2019, 00:52
500kb is too big
but why is 500kb too big ? For me it seems there is something unnecessary in the bin-file.. or the images are rewritten NOT compressed (if I have 2 bigger images in, the .bin-size increases more than the filesize of the two bigger images!)..
Is there something that can be left out, like the preview gif ? I tried modifiying the python script setting the size of the gif to 1x1, sadly has no effect to the bin-size. Other ideas ?
Re: py amazfit tool
Enviado: 24 Dez 2019, 12:43
por hikashi
schwedenpaule escreveu: 18 Dez 2019, 17:25
500kb is too big
Unfortunately we have to work around with the 2 mb limit. The biggest contributor to the bin size is the asset dimension size regardless of content or quality of compression.
Re: py amazfit tool
Enviado: 28 Dez 2019, 02:25
por hikashi
Sharing some working syntax with analog dial.
"DaysProgress": {
"AnalogMonth": {
"OnlyBorder": false,
"Color": "0x00000000",
"CenterOffset": {
"X": 84,
"Y": 0
"Shape": {
"X": 0,
"Y": 0
"Sector": {
"StartAngle": 0,
"EndAngle": 33000
"Image": {
"X": 5,
"Y": 44,
"ImageIndex": 12
"AnalogDOW": {
"CenterOffset": {
"X": 0,
"Y": 92
"Shape": {
"X": 0,
"Y": 0
"Sector": {
"StartAngle": 0,
"EndAngle": 30858
"Image": {
"X": 5,
"Y": 35,
"ImageIndex": 13
"StepsProgress": {
"ClockHand": {
"CenterOffset": {
"X": -84,
"Y": 0
"Shape": {
"X": 0,
"Y": 0
"Sector": {
"StartAngle": -15000,
"EndAngle": 15000
"Image": {
"X": 5,
"Y": 44,
"ImageIndex": 13
Re: py amazfit tool
Enviado: 31 Dez 2019, 09:43
por Louis_Cypher
500kb is too big
Resizing 001.png (the preview image) to 266 pixels reduced my .bin from 2mb to 1,5mb. Perhaps making it even smaller can decrease .bin for less than 1mb (I didn't try yet).
It looks like the problem is with .gif created during packing. It uses 10 frames, and I think it's not compressed.
Re: py amazfit tool
Enviado: 01 Jan 2020, 03:04
por hikashi
Louis_Cypher escreveu: 31 Dez 2019, 09:43
Yes. The 266 sized png is meant for 0001.
The gif created is not part of the bin file.
Re: py amazfit tool
Enviado: 04 Jan 2020, 15:11
por aliense
Why sometimes when i try unpack bin i got this err:
2020-01-04 16:07:49,979 - root - DEBUG - Opening watch face 'gtr.bin'
2020-01-04 16:07:49,979 - root - DEBUG - Reading parameters...
2020-01-04 16:07:49,979 - root - INFO - Reading header...
2020-01-04 16:07:49,988 - root - INFO - Header was read:
2020-01-04 16:07:49,988 - root - INFO - Signature: b'O3\x04\x00\x00\x00\x10', Unknown: 3725067530, ParametersSize: 308940802, isValid: False
2020-01-04 16:07:49,988 - root - DEBUG - Parsing parameters...
2020-01-04 16:07:49,988 - root - CRITICAL - 'Reader' object has no attribute '_parameters'
File "C:\Users\alien\Desktop\Zegarek\py_amazfit_tools-master\program*py", line 161, in parseResources
return ParametersConverter.parse(WatchFace, reader.getParameters())
File "C:\Users\alien\Desktop\Zegarek\py_amazfit_tools-master\watchFaceParser\reader*py", line 12, in getParameters
return self._parameters
AttributeError: 'Reader' object has no attribute '_parameters'
Re: py amazfit tool
Enviado: 04 Jan 2020, 15:29
por afwafwafw
aliense escreveu: 04 Jan 2020, 15:11
There's a issue with negative values for spacing or positions.
I've fixed some but let me know if you still have this issue with latest codes.
Re: py amazfit tool
Enviado: 06 Jan 2020, 00:02
por vadim.t
afwafwafw escreveu: 04 Jan 2020, 15:29
File "program*py", line 161, in parseResources
File "\watchFaceParser\reader*py", line 12, in getParameters
Hi! Thank you for this amazing tool! I would like to make few changes to the standard watch face "Orange light" provided for GTR 47, but I get the same error while unpacking a bin file (I use the latest version of your app). Can you please advise? The file is on google drive /open?id=1NE8sYuYnihxpFVJVB8-51Lv9Ud_EIDAO
Here is a fragment of my log:
2020-01-06 00:37:18,502 - root - INFO - Header was read:
2020-01-06 00:37:18,502 - root - INFO - Signature: b'O\xc8\x05\x00\x00\x00\x10', Unknown: 2735211786, ParametersSize: 305074177, isValid: False
2020-01-06 00:37:18,502 - root - DEBUG - Parsing parameters...
2020-01-06 00:37:18,503 - root - CRITICAL - 'Reader' object has no attribute '_parameters'
Re: py amazfit tool
Enviado: 06 Jan 2020, 02:51
por afwafwafw
vadim.t escreveu: 06 Jan 2020, 00:02
It seems like compressed bin.
Normal bin should have 'HMDIAL' for signature field as far as I know.
Maybe SashaCX75's tool can decompress these kind of .bin. (
viewtopic.php?f=29&t=1076 )
Is there any open explanation for compression used in these format? I want to know.
Re: py amazfit tool
Enviado: 06 Jan 2020, 11:51
por Horatius80
Horatius80 escreveu: 06 Jan 2020, 11:49
Re: py amazfit tool
Enviado: 07 Jan 2020, 09:17
por afwafwafw
Horatius80 escreveu: 06 Jan 2020, 11:51
This one also looks like compressed one.
Not normal(uncompressed) header.
Re: py amazfit tool
Enviado: 07 Jan 2020, 14:25
por kampanita
I'm having trouble with this one.
Seems to be ok but does not get installed. I see no error but does not run at watch ( gtr-47 )
If i quit weather and weekday parts, it runs ok...
https://amazfitwatchfaces.com/gtr/view/2714
Re: py amazfit tool
Enviado: 07 Jan 2020, 15:56
por asoo
kampanita escreveu: 07 Jan 2020, 14:25
After adding "weather" and "weekday"
Your .BIN file (uncompress) size over 2M or not?
If the .BIN (uncompress) size is over 2M. It may not be able to be installed.
