AmazFaces for iOS [Support]
Has thanked: 1162 times
Been thanked: 278 times
In this topic, you may report a problem with our AmazFaces app for iOS.
App version (Stable or Beta)
Watch model
Phone model
OS version
Description of your problem
Filling example:
App version: 3.0.111 Stable
Watch model: GTR
Phone model: iPhone 11
OS version: iOS 14.2
edu_kuniy
Post by edu_kuniy »
AmazFaces Version 3.6.120
T-Rex
iOS 14.7.1
After the last update I cannot change any skin … I keep receiving this Sending status all the time … look at the picture
Stas
Been thanked: 34 times
Post by Stas »
Thank you for screenshots, fixes for t-rex try checking beta version 122 and write the test result.
link to beta test TestFlight:
https://testflight.apple.com/join/4hBEKHHg
edu_kuniy wrote: 19 Sep 2021, 06:56
T-Rex
iOS 14.7.1
extremme
Post by extremme »
extremme wrote: 19 Sep 2021, 03:15
App version: 3.6.120
Watch model: T REX
Phone model: iPhone 11 Pro Max
OS version: iOS 14.8
I have a T-Rex. I was able to download and update my watch faces without issue. The last time I changed was abt 2 months ago.
I am using Iphone 11 pro max and 2 days ago, I updated the IOS to 14.8.
I tried updating the faces to my watch. It will indicate on my watch "Syncing Watch....." and on my phone it will show the progress. When it reached 100%, my watch will show error to upload face. I tried many times and tried to reinstall Amazfaces app but to no avail. (My Zepp app was still running at the background)
I then tried to use the Zepp app to try and see if I can change the face using their default watch faces and it worked. So it not bluetooth connection issue.
This is resolved with the latest update to 124. Thks developers!
click9000
Post by click9000 »
Here is my experience finally how to get watch face uploading to my T-Rex watch again using iOS app on my iPhone7 (since it stopped working three months ago). Thinking it might help some people having same trouble.
1. Make sure Zepp app is not in background. If you found it, kill it. (it causes T-Rex won't show in the device list AmazFaces app for me)
2. Install the latest AmazFaces (3.7.124)
3. Open AmazFaces app, select watch face you like and click download button. You should see T-Rex in display. Click Install button to install.
The reason I got stuck before was that they told us Zepp app needs to in background when using AmazFaces. It turned out to be a show stopper not sure when it started, and I just figured it out after trial and error.
broook
Post by broook »
App version :AmazFaces ver.3.7.124
Watch model: t rex
Phone model iPhone 12
OS version iOS 15
Description of your problem: can't discover watch by Amazfaces app
Stas
Post by Stas »
Check the visibility of the watch in Zepp and restart the bluetooth, in the next update the search for the device will be fixed
broook wrote: 11 Oct 2021, 09:59
Watch model: t rex
OS version iOS 15
broook
Post by broook »
Stas wrote: 11 Oct 2021, 11:40
Watch model: t rex
OS version iOS 15
it works flawlessly in Zepp app , the problem is only on Amazfaces, I restarted the bluetooth and I stoped the Zepp app running at the background , but still the watch is not visible. may be its fixed by the next update as you said.
wing0826
Has thanked: 9 times
Post by wing0826 »
big bug...
when i just sync a new watch to GTR2
sync -> error -> auto re-sync ->error -> auto re-sync -> ....
I only can reboot GTR2 to stop the issue
App version: 3.7.124 / 3.8.125
Watch model: GTR2
Phone model: iphone xs max
OS version: iOS 13.5.1
Stas
Post by Stas »
The reboot of the bluetooth helps, in the next update we will try to solve this problem.
7pixel wrote: 17 Oct 2021, 07:18
Watch model: T REX
OS version: iOS 15.0.2
Can someone fix it please?
edu_kuniy
Post by edu_kuniy »
Add to Favorites > Not working … I touch Add to favorite but it doesn’t show on favorites tab … look 👀 at the pictures 📸
iPhone 12 ProMax
iOS 14.8
AmazFaces app 3.7.124
T-Rex ( not the New T-Rex Pro )
Stas
Post by Stas »
Updates are not done as quickly as we would like, within a few days I think a version with fixes will be available.
edu_kuniy wrote: 29 Oct 2021, 19:20
iPhone 12 ProMax
iOS 14.8
frankhj
Post by frankhj »
App version (Stable or Beta)AmazFaces ver 3.8.126
Watch model Bip S
Phone model iPhoneSE
OS version 15.1
It continuously says connecting after selecting install but it never connects. I can change faces with the Zepp app.
Stas
Post by Stas »
try to remove the bipS from the app AmazFaces and reconnect through the search, before that, restart the watch and bluetooth on the phone
frankhj wrote: 05 Nov 2021, 03:48
Watch model Bip S
OS version 15.1
frankhj
Post by frankhj »
Did all that and issues screen pops up after clicking install.
broook
Post by broook »
hi team,
I have Amazfit Trex... is there an option to delete the default watch faces on the trex so that I can upload my favorite watch faces up to three.
thanks,
frankhj
Post by frankhj »
frankhj wrote: ↑04 Nov 2021, 22:48
Watch model Bip S
OS version 15.1
I tried correcting the problem by doing the steps you recommended and it still would not connect and the "Issues" screen popped up.
I solved the problem by installing the AmazTools app and uploading the face I wanted to Amaztools. The installation through AmazTools worked without any problems.
Stas
Post by Stas »
Within a week there will be an update with a fix
7pixel wrote: 23 Nov 2021, 17:04
App version: 3.8.126
Watch model: T REX
OS version: iOS 15.1
Stas
Post by Stas »
frankhj wrote: 06 Nov 2021, 19:47
Watch model Bip S
OS version 15.1
cartina21
Post by cartina21 »
App version: 3.9.130
Watch model: Mi Band 6
Phone model: Iphone 13 Pro Max
OS version: 15.2.1
The app is not able to find the device
Stas
Post by Stas »
Choose watch model
cartina21 wrote: 20 Jan 2022, 12:58
OS version: 15.2.1
cartina21
Post by cartina21 »
there isn’t watch model
Stas
Post by Stas »
If it does not find the clock:
1.Check the visibility of the watch.
2.Reboot the bluetooth module on your phone.
2. Restart your watch.
Downloading the watch face for band6 does not work correctly at the moment, a fix is expected within a month.
cartina21 wrote: 22 Jan 2022, 21:15
jdmf13
Post by jdmf13 »
For several versions now I have been unable to login to my AmazfitWatchFaces account, I fill in my Username and Password and I get the spinning wheel but 5....10....15min go by and it never logs in.
Is logging in broken?
Sabryzeeo
Post by Sabryzeeo »
I have an iphone Xr ios 15.1 with Zepp and amazfit installed
but i can't install the watchface can't connect with my GTS
plz help! :shock:
NeoSDAP
Post by NeoSDAP »
App version: 3.9 Stable
Phone model: iPhone 8
OS version: iOS 15.5
It only allows me to download watchfaces, basically without letting me sync them. This does not happen with my Mi Band 4, which allows me to sync¡them correctly.
Return to “AmazFaces app”
