If you find any bug in the use of AMAZFIT verge lite, please leave a comment here [Verge Lite]
For example: Screen timeout question [Stratos 3]
After actualization mi fit and watchfaces app not syncing watchfaces.
xilansfroid
Could anyone make a tutorial to install the firmware 1.3.2.00? I'm trying to update using Notify App and it's not working. Thank u
I have observed that my Lite verge do not reboot if its fully charged. The lower the battery the sooner it got restarted while using GPS.
Can someone validate this with their watch please. Also I raised this with Amazfit team and they replied that they are aware of the issue and working on a firmware update to fix this.
It should be available in mid July.
Thanks.
Thanks.
rogeriodeluca
Here having the same problem...maslo1979 wrote: 25 May 2021, 15:50After actualization mi fit and watchfaces app not syncing watchfaces.
rogeriodeluca
The problem with the watchfaces doesn't happen with fully charged battery....
I have the some problem with GPS but only then i m running, if i use It in home the Gps work
all,
Has anyone experienced when wearing verge lite and run after running for a short while lets say 8-10 mins then the watch always switched off itself, I need to switch on it again but all recorded values (distance, pace, HR etc.) disappeared already, it is being as this behavior every times when uses it to run.
I used to see some people have been facing this problem and post to ask this kind of question somewhere too, but no answer.
I have done hardware reset to factory setting already, this problem is still remaining.
Anyone knows the root cause or how to solve this problem will be very appreciated.
Thanks.
Chanapol
[email protected]
Thanks.
Chanapol
[email protected]
I try with full charge but don´t work on firmware 1.3.2.00rogeriodeluca wrote: 10 Aug 2021, 00:27The problem with the watchfaces doesn't happen with fully charged battery....
