Página 3 de 9
Publicado: 09 Sep 2019, 07:17
por lumenvindex
Download WF_Builder 1.0.4
Changelog
Código: Seleccionar todo
1.0.4
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
Re: WF_Builder (watchfaces for Mi Band 4)
Publicado: 15 Oct 2019, 10:46
por lumenvindex
Notarino escribió: 15 Oct 2019, 10:03
Could anyone make the watchface ???
You should ask about it here.
If you have some problems with WF_Builder, be more specific.
Publicado: 15 Oct 2019, 12:25
por phamaral
You can only use transparency of the image to show what's under the battery icon.
Thanks for the tip! That probably will work in my case. Only problem I'm facing now is getting a usable file size using the "as is" packing method since pallete won't allow partially opaque images. Any ideas?
Publicado: 15 Oct 2019, 13:29
por lumenvindex
phamaral escribió: 15 Oct 2019, 12:25
Palette mode doesn't allow to use partly-transparent colors in the image, it turns such pixels into fully opaque or fully transparent.
But if you need to have partly-transparent colors in SOME (not all) of the images, you can enable "Selective palette mode" feature in Options dialog and select some images to be left "as is" during the packing procedure.
Publicado: 15 Oct 2019, 14:51
por technofab
Very useful tool. A request if actual is not possibile: how I can select month day in the format DD MM or MM DD ? for now I see only MM DD! Thanks in advance.
Publicado: 15 Oct 2019, 15:15
por lumenvindex
technofab escribió: 15 Oct 2019, 14:51
You can't change the format for One line date, but you can use Separate - Day and Separate - Month placing them nearby. The separator can be drawn on a background image if needed.
Publicado: 15 Oct 2019, 15:19
por technofab
lumenvindex escribió: 15 Oct 2019, 15:15
yes, I'm testing that, but I need to remodify the background image. It wasl helpful if the oneline date can be selectable in both modes or the separate day - month can have a seperator image to select.
Publicado: 15 Oct 2019, 16:25
por lumenvindex
technofab escribió: 15 Oct 2019, 15:19
Sadly, the Mi Band firmware doesn't allow that.
Publicado: 16 Oct 2019, 18:14
por tigre652
I have cteate my first watchfacr with etitor
I have push save as and create a folder with a png file... and now?
How create a bin file?
Publicado: 17 Oct 2019, 03:18
por lumenvindex
tigre652 escribió: 16 Oct 2019, 18:14
To create a bin file you need to Pack the watchface in palette or raw ("as is") mode. Read Help to know the difference between them.
Publicado: 17 Oct 2019, 04:28
por tigre652
Message error pack palette is failed!
Publicado: 17 Oct 2019, 08:51
por tigre652
Packing failed
Publicado: 17 Oct 2019, 09:19
por lumenvindex
tigre652 escribió: 17 Oct 2019, 08:51
Packing failed
WF_Builder uses Mi Band 4 WF Tool for packing. Check it's log file in the json directory.
Publicado: 17 Oct 2019, 11:24
por lumenvindex
WF_Builder 1.0.3 is uploaded. Check the original post.
Publicado: 17 Oct 2019, 13:08
por tigre652
Ok i complete my work:
https://amazfitwatchfaces.com/mi-band-4/view/8211
1 Two problem, I cannot align the numbers of steps and pulses on the right as you can see from the preview.
2 Is it possible to enter the outside temperature?
Publicado: 17 Oct 2019, 13:17
por tigre652
tigre652 escribió: 17 Oct 2019, 13:08
1 3 problem, I cannot align the numbers of steps and pulses on the right as you can see from the preview.
3 why the date and date on the pulse and steps disappear after 1sec?
Publicado: 17 Oct 2019, 13:30
por lumenvindex
1. Horizontal alignment works only when ALL the numbers+spacings fit into the box from X1:Y1 to X2:Y2 horizontally.
Vertical alignment works only on images which fit into the box from X1:Y1 to X2:Y2 vertically.
2. No, current firmware doesn't support this.
3. Current firmware(s) bug.
Publicado: 17 Oct 2019, 13:35
por tigre652
3 is problem firmware miband4, not software tools?
Thanks for your work.
Publicado: 17 Oct 2019, 13:37
por lumenvindex
tigre652 escribió: 17 Oct 2019, 13:35
Yes, it's a bug of Mi Band firmware.
Publicado: 19 Oct 2019, 09:01
por technofab
lumenvindex escribió: 15 Oct 2019, 16:25
Ouch, very sad. Thanks for the explanation. :)
Publicado: 19 Oct 2019, 15:57
por TaylanTatli
Can you make a linux version? Trying to run with wine but it seems broken;
imggmi .com/full/2019/10/19/853398f0b414333a42e0163a6b08314c-full.png.html (remove the space site doesn't allow me to share image)
Publicado: 19 Oct 2019, 16:05
por lumenvindex
TaylanTatli escribió: 19 Oct 2019, 15:57
The only way to make a linux version is to write the program from scratch using some other than Autoit language. I'm not planning to do it.
Publicado: 21 Oct 2019, 11:56
por technofab
lumenvindex escribió: 19 Oct 2019, 16:05
Wow is made with AutoIt? Many many compliments. I use that at my job!!!
I want also to thank you, I made my first personal face, and publish here.
Fiorentina Fans had finally a watchface! :D
Publicado: 24 Oct 2019, 14:26
por Nomek
Just one question. Is there a detailed command list for the *.json file?
I'm trying to find out if there is a command "Year" to add the current year in Mi Band 4 watchface.
Any kind of help is wellcome.
Publicado: 24 Oct 2019, 16:19
por jellynettle
I don't think there is but you can easily just put 2019 in the background, updating it manually if you'll still like said watchface
Publicado: 24 Oct 2019, 17:52
por lumenvindex
Nomek escribió: 24 Oct 2019, 14:26
WF_Builder uses all known json parameters. You can find the list of them in this file:
right_order.zip
(1.34 KiB) Descargado 285 veces
There is no Year section or value.
