Page 15 of 20
Posted: 07 Mar 2021, 10:37
by SashaCX75
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Posted: 02 Nov 2021, 09:34
by Max88
SashaCX75 wrote: 09 Oct 2021, 14:14
If you have any questions about the GTS 2 mini, it is better to contact the @neFAST user. As far as I know, he has made a lot of progress in terms of working with these dials. Maybe he wants to create a separate thread on this forum.
Those who have problems installing python can use this utility. It is based on this project, but should work without installing python. I can’t check its performance, I don’t have a GTS 2 mini.
I have a gts 2 mini and i can confirm this unpack tool works. I have tested it with some watchfaces i created on huami site and it works perfectly. I have unpacked and repacked one i created.
Thanks to users who created it, you have opened me a world :D
hope to see a tool one day, one as this of sasha. Thanks again guys!
Posted: 04 Nov 2021, 16:34
by Tradis
First of all, SashaCX75, Thanks for this great watch face editing tool!
I have a simple question, there will be in future a GTR 3/3 Pro update?
Thank you for your big work!
Posted: 06 Nov 2021, 15:53
by SashaCX75
Tradis wrote: 04 Nov 2021, 16:34
I have not decided yet, but most likely I will make a new editor for GTR 3. But even so, it is unlikely that it will be ready this year.
Posted: 07 Nov 2021, 16:54
by demiurg1
It would be nice if there was a converter from GTR 2 to GTR 3 in it. If it will be with some restrictions, then also OK. It is important that the conversion is possible. It would be a pity to make new projects for the GTR 3 again, as if I decided to buy a new smartwatch model. It is good that the possible plan assumes a longer implementation date.
Posted: 12 Nov 2021, 18:13
by Max88
Sasha could you tell me where to look for updated of this utility for gts2 mini?
I mean.. is there a site or a person to contact to check if there are updates of the tool?
Posted: 12 Nov 2021, 19:19
by SashaCX75
Max88
In addition to the information in the quoted message, I have no other
Posted: 17 Nov 2021, 17:40
by knorde
Maybe a stupid question, but in "amazfit watchface editor 2" I made a watchface for the GTR2(e). But how do I upload this to my smartwatch now?
Because I want to keep it private, I don't want to put it online but only on my smartwatch. Is that possible?
Posted: 17 Nov 2021, 20:35
by Cooperphile
Mark it private when you upload it here. Install on your watch. Delete it from here if you want to.
Posted: 18 Nov 2021, 07:06
by knorde
I have no option for that (no trigger).
I see this:
Make private Only one watchface in each section of the catalog can be private. View existing: You do not have any uploaded watch saces.
No option to turn on make private.
Posted: 18 Nov 2021, 12:27
by GIK-Team
knorde wrote: 18 Nov 2021, 07:06
I see this:
This option is only available to those who are in the Watchface makers group.
To enroll in a group, you need to upload several watch faces to the site.
Posted: 18 Nov 2021, 13:25
by knorde
I wouldn't want to put watchfaces online right before testing, I still find it very difficult and I still have a lot to learn about it. It is very difficult for me to put a number of watchfaces online before I can start testing and learning.
Is there no other way to upload it to my watch?
Posted: 18 Nov 2021, 14:22
by GIK-Team
knorde wrote: 18 Nov 2021, 13:25
viewtopic.php?t=783
Posted: 24 Nov 2021, 01:11
by RizkyFz
If you're on Android you can use Notify for Amazfit. That app allow you to upload custom wf directly into your watch. That's what i'm using for testing wf.
Anyway Sasha, i'm making (convert) a wf https://amazfitwatchfaces.com/gts/view/6826 and after compiling it with Amazfit WF editor the size became really huge. It's became ~30mb when uncompressed while the resources of that wf are less than 1mb. Making the watch a little slow when using that wf. It is possible to reduce the size?
Initially i make the wf with huami editor but it's failed when exporting, it's says the size is too huge.
Posted: 25 Nov 2021, 11:03
by istanbulls
I am Amazfit T-Rex Pro user.
I've done a few WatchFaces and I'm still learning a lot.
Thank you very much to those who made this program, you helped me develop.
I have a little question. I can't do anything for always-on display, am I incompetent or does the program not have this support?
sorry for my bad english, i use google-translate
Posted: 25 Nov 2021, 16:47
by SashaCX75
RizkyFz wrote: 24 Nov 2021, 01:11
This is a bad example of a watch face. Replace the pictures with circular progress and the size of the dial will be greatly reduced.
Posted: 25 Nov 2021, 16:50
by SashaCX75
istanbulls
On the "Editing" tab there is a switch which screen to edit, main or AOD.
Posted: 26 Nov 2021, 11:45
by RizkyFz
SashaCX75 wrote: 25 Nov 2021, 16:47
I see the .json file from the original maker (gts 2 mini) and he's using image progress, not circle progress. So i tried to replicate it to gts 2 using the same method.
Now i just tried to change it to circle progress. Now the size greatly reduced but i'm kinda confused with how Radius, Width, Start angle, and End angle value works. I'm just guessing the number for now and it works for Steps and Kcal by setting the Radius and Width value to 100, Start angle to 90 and End angle to 360, and X=175 Y=220. But strangely the same values configuration doesn't work for my battery circle progress. I need pointer how these values works.
Posted: 26 Nov 2021, 17:54
by SashaCX75
RizkyFz
For your dial for steps, calories and charge X = 174, Y = 221, start angle 180, end angle 360. For charge, radius 31, line width 41.
Posted: 26 Nov 2021, 18:01
by SashaCX75
Version 7.3
Posted: 28 Nov 2021, 08:26
by zyfish
thank you very much。sashacx75
Posted: 28 Nov 2021, 12:48
by demiurg1
SashaCX75 wrote: 26 Nov 2021, 18:01
Version 7.3
I congratulate you on your purchase.
I understand that you will now make an editor under GTR 3. Will it also support GTR 3 Pro? Will any conversion of watch faces from GTR 2 to GTR 3 (and Pro) be possible? I am thinking of buying a new model, because I feel sorry for my designs of watch faces, which I made for the GTR 2. I don't want to make them again.
Where do you recommend the purchase?
Posted: 29 Nov 2021, 19:18
by Ferrari70m
Hello. Today I created my first watchface with the great editor (thanks SashaCX75).
No I have the problem, that my WF were overwritten on watch. I think the problem is the same WF-ID.
How can iÍ creat a unique ID for my own WF?
Could someone help me please?
Posted: 29 Nov 2021, 19:43
by asoo
Ferrari70m wrote: 29 Nov 2021, 19:18
you can use [Generate] to random Generate watchface ID , or edit on json Box and save , after saved go to Browse ---> "[select] json with image" open your .json again.
Posted: 06 Dec 2021, 09:26
by Tradis
SashaCX75 wrote: 06 Nov 2021, 15:53
Thank you for your reply and for your work. I'm a .net developer, if i can help you to develop the tool, i'll be glad to do it! :D
Posted: 06 Dec 2021, 10:08
by Superwitschi
Hello, if i add weather and pack an compress bin then there is no watchface bin in the folder. Somone a idea?
Edit: never mind, i finally got it to work.
