Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
wymswm
Post by wymswm »
albertowd wrote: 04 Mar 2020, 02:40
A quick tip for Photoshop users when saving PNG-24 preset:
When saving a solid PNG (with no transparent pixel, ex.: a full background picture), the exporter does not includes the alpha channel on the final file, leaving it with a true 24-bit PNG file.
The tool will use the same mask for all image files, so if the background image is solid but all other images are transparent, it will save as a 32-bit PNG file and it will crash the bin packer.
Solution: when using transparent and solid images, save solid ones with the normal "Save As ..." option so it will not be optimized into a different bit mask.
I use pscs6 save as 32-bit PNG
in XXX__packed.log
2020-09-15 23:30:55,247 - PIL.PngImagePlugin - DEBUG - STREAM b'IHDR' 16 13
2020-09-15 23:30:55,248 - PIL.PngImagePlugin - DEBUG - STREAM b'pHYs' 41 9
2020-09-15 23:30:55,248 - PIL.PngImagePlugin - DEBUG - STREAM b'iCCP' 62 2637
2020-09-15 23:30:55,248 - PIL.PngImagePlugin - DEBUG - iCCP profile name b'Photoshop ICC profile'
2020-09-15 23:30:55,248 - PIL.PngImagePlugin - DEBUG - Compression method 0
2020-09-15 23:30:55,248 - PIL.PngImagePlugin - DEBUG - STREAM b'cHRM' 2711 32
2020-09-15 23:30:55,248 - PIL.PngImagePlugin - DEBUG - STREAM b'IDAT' 2755 227938
use Drawing 3D with win10
in XXX__packed.log
2020-09-16 00:25:05,934 - PIL.PngImagePlugin - DEBUG - STREAM b'IHDR' 16 13
2020-09-16 00:25:05,934 - PIL.PngImagePlugin - DEBUG - STREAM b'sRGB' 41 1
2020-09-16 00:25:05,934 - PIL.PngImagePlugin - DEBUG - STREAM b'gAMA' 54 4
2020-09-16 00:25:05,934 - PIL.PngImagePlugin - DEBUG - STREAM b'pHYs' 70 9
2020-09-16 00:25:05,935 - PIL.PngImagePlugin - DEBUG - STREAM b'IDAT' 91 65445
The bin file can't be generated by the two methods
What software should I use to save PNG images?
wymswm
When using Photoshop, the safest way to avoid errors is to add at least one transparent pixel.
Part of the second log file looks fine. If the bin file does not appear, then there may be an error in something else. It is necessary to find in the log file exactly where the error is.
Atia
Post by Atia »
Hello!
I remake, convert, edit some face. But i have one problem.
https://amazfitwatchfaces.com/verge-lite/view/1255
This face sync sucessfully and changed my verge lite.
https://amazfitwatchfaces.com/verge-lite/view/1268
This face sync sucessfully but not changed my verge lite. The original face worked...
I try with Mi Fit and Zepp (aka Amazfit) apps...
What the problem the second face? Please help.
Thank You for answer.
Have A Nice Day.
Atia
The file on the second link is corrupted. Try to create it again or use an uncompressed file.
To check the correctness of the created bin file, try to unpack it with the editor.
Elsa.von.Arendelle
Post by Elsa.von.Arendelle »
Step progress no works by my Creations for verge Lite :( What is the Failure ?
Anyone can Test ist and show it ? here exmaple for DL https://amazfitwatchfaces.com/verge-lite/view/1320
Elsa.von.Arendelle
I found the mistake.
That's the way it is:
"StepsProgress": {
"Circle": {
"CenterX": 180,
"CenterY": 180,
"RadiusX": 135,
"RadiusY": 135,
"StartAngle": 0,
"EndAngle": 360,
"Width": 4,
"Color": "0x0000FE21",
"Unknown9": 0
The program ALWAYS saves the json incorrectly. It ALWAYS stands
"StepsProgress": {
"Circle": {
"CenterX": 179,
"CenterY": 179,
"RadiusX": 177,
"RadiusY": 177,
"StartAngle": 0,
"EndAngle": 360,
"Width": 6,
"Color": "0x006FBDA8",
"Flatness": 0
No matter what you set. It always saves with "Flatness": 0
Is it a bug?
You have to change the json flatness to Unknown9 manually. Then it works
Elsa.von.Arendelle
It should be "Flatness". The "Unknown9" parameter was in older versions. If you only work with the "Unknown9" parameter, then perhaps you unpacked the new version of the program over the old one. Reset settings in the program or unpack it into a new folder.
KA_
Post by KA_ »
GTR user. Is there a chance to add more shortcuts? To messages, compass? Or it is firmware limited to four that now exist? Thanks for reply.
And seems that "Alignment": "TopRight" dont work. All image combos are alignment to left.
KA_
No, other shortcuts are not supported by the firmware.
The alignment does not work if the label does not fit into the rectangle specified by the coordinates. Decrease the coordinate of the top left corner.
hemendex
Post by hemendex »
sorry if i ask stupid but is there a functional transfer from KM to MI? For T-Rex.
yiic
Post by yiic »
Thanks a lot, I am learning...
DragoNuno
Post by DragoNuno »
I notice that when you are using an image for a progress bar, the line ending changes aren't shown in the preview window. They all show flat but in the watch it does have an effect.
Also, this warning isn't translated to english. What does it mean?
Many thanks!
DragoNuno
Google Translate
It is recommended to use 6 segments to display the heart rate.
I know that the pictures for animation don't have to be last. If there is such a problem for other indicators, I will check and try to add a warning in the next version.
Suwaid
Post by Suwaid »
gizmo2k4 wrote: 30 Dec 2019, 22:31
Once u have created all the elements. Goto the tab editing and select Save JSon
Then goto the first tab Upack/pack and select Pack and compress bin and select the JSon file that u saved just now
jjkielce
Post by jjkielce »
First of all, big applause to you Sasha CX75 for creating this program. The program is easy, pleasant and clear. I only have a problem with the analog tips. I am never sure which tip and why is on the 1st plan and what dependencies are guided by it. The same goes for the other tips. I recently did a dial for the GTR with pulse progression, and this tip is in the background. I do not have GTR and I do not know what the final effect of the work will be. Maybe you can explain how it works. I wish you good health.
jjkielce
If we are talking about the hands on the analog dial, then first the hour hand is drawn, above it the minute and second hands. If the second hand is off-center, it is drawn below the other hands.
In the editor, I tried to take into account the drawing order of the elements, and in most cases the image in the program matches the image on the clock.
jjkielce
Post by jjkielce »
thanks for the answer. Unfortunately, the preview is correct and not on the dial anymore. if you can view this file. and see what with the pulse arrow, please. gts/view/3242 lub gtr/view/9106
jjkielce
Looked at gtr/view/9106 dial. The pulse arrow on the watch and in the program seems to be displayed the same way. But I don't recommend making the difference between the start and end angles greater than 360.
jjkielce
Post by jjkielce »
BUT THE ARROW ON THE WATCH IS UNDER THE BOTTOM. SAME WITH THE ARROW OF SECONDS. PLEASE CHECK THE SECOND ARROW.
branislavpoposki
Post by branislavpoposki »
Is there a way to add shortcuts for timers, countdown, compass etc. to your watch face. I have amazfit t-rex and i can't find anything helpful on this topic.
jjkielce
The pulse arrow on the watch and in the editor (v 8.5) is displayed below the rest of the arrows.
The second hand is not displayed correctly, will be fixed in the next version.
If I misunderstood you, then show on the screenshot what exactly is wrong.
branislavpoposki
Only 4 types of shortcut can be added in the editor. I don't know if all these types of shortcuts work on t-rex.
marek29
Post by marek29 »
SashaCX75 wrote: 16 Oct 2020, 15:29
THANK YOU FOR YOUR INTEREST. PULSE PROGRESSION IS NOT IMPORTANT MATTER. THIS SHIELD IS NOT IMPORTANT TO ME, I WILL WAIT WITH HER FOR A NEW VERSION. IT IS MORE IMPORTANT TO UNDERSTAND THE ARRANGEMENT OF THE MINUTE, HOUR AND SECOND ARROW. NOT ALWAYS THE RESULT IN THE PROGRAM GIVES A DISPLAY ON THE WATCH. I CAN SOMEONE ADVISE ON GTS BECAUSE I CAN CHECK IT. ON GTR NO MORE AND IT BURNS ME. GREETING, AND THANK YOU FOR CREATING THIS PROGRAM. YOU ARE GREAT .
wing0826
Has thanked: 9 times
Post by wing0826 »
hi, SashaCX75
will GTR_WatchFace editor support GTR2/GTS2/ZEPP-E ?
No. In GTR2 / GTS2 another way to create a bin file. I don't know a way to parse the bin file from GTR2 / GTS2 yet.
marek29
Post by marek29 »
I think I already know what are the dependencies in the position of the arrows. after many attempts I come to the conclusion that the position of the central image is of key importance. Thank you very much for your interest and I wish you good health and success.
