Page 11 of 20
Posted: 07 Mar 2021, 10:37
by SashaCX75
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Posted: 09 Jul 2021, 08:57
SashaCX75 wrote: 12 Apr 2021, 07:58
Is it possible to swap the watchface from GTR2 to GTR47mm?
Posted: 09 Jul 2021, 14:11
by SashaCX75
[email protected] wrote: 09 Jul 2021, 08:57
Not. You can only extract resources from the GTR2 dial and use them to make a dial for the GTR47.
Posted: 10 Jul 2021, 15:41
by theleon
Downloaded the latest version, and when trying to open any GTR 2 watchface, I get the following errors:
- "PNG files go out of order or some of the files are missing"
and right after:
- "Invalid JSON file. ... Cannot deserialize current JSON arary into type 'GTR_Watch_face.ImageW'"
While the errors can be clicked away, the preview stays blank. Any idea what I'm doing wrong?
It's my first time using this editor.
EDIT: Nevermind, got it to work. Had downloaded the "GTR (GTS, T-Rex) to GTR2 (GTS 2, T-Rex Pro) Converter & Editor" instead of the Version 5.0... Didn't realize you could click on the Version 5.0, woops.
Posted: 12 Jul 2021, 00:48
by EXS
Hi everyone, I have a question, Im translating a watchface from czech to english, it's my first time trying the app. What do I do about the "Watchface.ID" file? Do I change the id to something else? How do I know what ID to use?
And there's anything else I need to do before packing it and sending to the website?
Posted: 12 Jul 2021, 14:26
by SashaCX75
EXS
The "Watchface.ID" file can be changed or deleted. But, in order to avoid mistakes, I advise you to use the appropriate button in the editor for this.
Posted: 12 Jul 2021, 15:10
by EXS
Thanks for the quick response, SashaCX75 .
I have another question: How do I add different pictures for different languages on a Watchface?
Example:
https://amazfitwatchfaces.com/t-rex/view/6396
I have this watchface in english but I would like to support other languages on it. How do I do it?
Posted: 12 Jul 2021, 15:57
by SashaCX75
EXS
No way. Just make a separate dial for each language.
Posted: 13 Jul 2021, 18:20
by Pal57
I just downloaded Ver. 5 for my GTR 2 but there are 2 labels on top near the "edit" label that are written in russian and even all functions inside of them are in russian.
I think they are the "Layer Order" and the "Editable Elements".
I would like to have them in italian.
Pal57
Posted: 14 Jul 2021, 10:42
by gg00
I cant open instructions from the app. Where can I find instructions?
Posted: 14 Jul 2021, 14:04
by SashaCX75
Pal07
I do not translate the program and only use the translations provided to me. If someone makes a translation, I will add it to the program.
gg00
Here is a link to instructions from the previous version of the program. But a lot will work for this version too.
viewtopic.php?f=14&t=1571
Posted: 15 Jul 2021, 22:48
by gg00
Thanks.
I have the following issue. After I uncheck analog clock from gtr 47 I then convert watch face to gtr 2 but dials are still there, they are not removed. What is the problem?
Posted: 16 Jul 2021, 11:59
by CASIONFAN2021
How do you use the editable zones.. im a bit stumped as to how to use them and what they are for..
Posted: 22 Jul 2021, 01:54
by LUCASREIS
Hi Sasha, unfortunately I couldn't do the values ​​related to the barometer in any attempt, I've done it in several ways.
Posted: 22 Jul 2021, 14:06
by SashaCX75
LUCASREIS
Doesn't work on T-Rex Pro. On GTR 2 (e), to update the barometer readings, you need to go to the clock on the widgets > altimeter. I have no information about how this parameter works on GTS 2.
Posted: 22 Jul 2021, 21:09
by gg00
All of sudden when I press to unpack bin nothing happens.
Posted: 24 Jul 2021, 06:44
by SashaCX75
Version 5.1
Posted: 30 Jul 2021, 08:07
by demiurg1
SashaCX75,
Thanks for the 5.1 version of the program, thanks to which I made my first project with "Editable Zones"
These are just two zones that I described at the link to my project: https://amazfitwatchfaces.com/gtr/view/16696.
In my next designs of watch faces, "Zones" will probably also appear.
Posted: 01 Aug 2021, 15:26
by LUCASREIS
Hi Sasha, I have the T-rex pro, and have been working on creating a "circle progress" related to dawn, to be aware of the time of daylight I have left to give instructions.
When I work out whatch against the parameters, sunrise and sunset look correct in the program, but when I install it on the watch the reference parameters of "circle progress" do not match the clock markings and the graph loses confidence.
All data has been checked and corrected including the angles but the problem persists.
Follow the photos to try to demonstrate.
Grateful for the attention.
Posted: 01 Aug 2021, 16:13
by SashaCX75
LUCASREIS
The sunrise time is 5:30 and the sunset time is 19:30 in the editor is selected conditionally. In reality, this time on the clock is constantly changing and depends on the selected city and season.
The "circle progress" indicator, in theory, should match the picture on the clock, which is in your message. But in reality, in the dial, he always lagged behind this image on the clock.
I got the impression that the dials for these paramaters do not take into account the time zone. But I can't do anything about it because the dials made in the official editor behave exactly the same. Perhaps for some cities these parameters are displayed correctly, so I did not remove them from the editor.
For me, only the sunrise and sunset times are correctly displayed, the other parameters do not work correctly.
Posted: 02 Aug 2021, 06:56
by nothing.tn
SashaCX75 Can you make tool to unpack file .bin for gts 2 mini. Thanks!!!
Posted: 02 Aug 2021, 14:13
by LUCASREIS
Hello @SashaCX75, I noticed that by the movement of the sun still dealing with the “circle progress” indicator it seems to keep the conditioned times in the editor not capturing the daily updated values ​​on the clock.
The “circle progress” indicator, in theory, should coincide with the clock image, which is in its message, but in reality, on the dial, it always lags behind that image on the clock.
I don't think it's related to the time zone, but rather to where the information is being collected. Because it seems to keep the data of (dawn = 05:30 and sunset = 19:30)
SashaCX75 wrote: 01 Aug 2021, 16:13
@LUCASREIS
Posted: 02 Aug 2021, 16:41
by SashaCX75
LUCASREIS
I wrote in my message that the “circle progress” for sunrise and sunset in the dial lags behind a similar indicator in the clock itself. I assume that this is due to the incorrect work of time zones. Since there are the same errors in the dials created in the official editor from the watch manufacturer, these are errors in the watch firmware.
nothing.tn
I'm not going to make a utility for unpacking .bin files for gts 2 mini. May editor uses a third-party utility to unpack .bin files/
Posted: 03 Aug 2021, 01:23
by nothing.tn
SashaCX75 what is that tool? Can you give me name, or link download. Many thanks!!
Posted: 03 Aug 2021, 23:05
by ScaredyCat
Is this the best place to report bugs?
GTR2e, latest firmware. All looks fine in the editor (version 5.1) but in the generated face the x coordinate seems to stick so that it's offset. I can change the Y with no issues. I tried moving I down to the right of the weather cloud just to see if I was doing somehitng dumb. It just lined up with the sam x corordinate - the y changed as expected.
In the editor I can position it where I want with no problems, the issue arises in the face after generation/installation.
Image attached, orange arrow point to the problem item.
Posted: 04 Aug 2021, 07:56
by SashaCX75
ScaredyCat
This is a bug in the watch firmware. If there is a weather icon and the temperature is aligned to the center, the inscription is aligned to the center of the icon. I cannot fix this, but I will try to take into account in the next update of the editor, so that the image in the editor matches the image in the clock.
