ZeppOS Player 2
Posted: 10 Sep 2026, 09:29
Hi everyone,
ZeppOS Player 2
Translate missing language
ZeppOS Player 2
Newest Release
Download v2.3.4
CHANGELOG
2.3.4 · September 17, 2026
2.3.3 · September 17, 2026
2.3.2 · September 16, 2026
2.3.1 · September 16, 2026
2.3 · September 16, 2026
Older Versions
VERSION 2.2.1
Download Release 2.2.1
CHANGELOG
VERSION 2.1.3
Download Release 2.1.3
CHANGELOG
VERSION 2.1
Release Start
Release Start
Future Versions
VERSION 2.4
Select a folder that contains incomplete works started with Editor 3 but not yet finished.
These will then be recognized in the player with the label “- Editor,” and you can test your unfinished WF files.
VERSION 2.X
If everything works and we're at nearly 99.9% Zepp compatibility, the next step is to develop our own editor.
But that's still a long way off.
TRANSLATE
Translations.xlsx
