Page 2 of 2
Posted: 11 Apr 2025, 21:11
by gingerbeardman
- #222222 grey @ 32px: %,♥
Re: Watchface image generator (web app tool)
Posted: 14 May 2025, 16:24
by SashaCX75
Great tool.
Small wishes.
Is it possible to make the preview always be at the bottom of the screen? Because now after changing the settings you have to scroll down the page to see the result and then go back to the settings?
Add full spelling for the names of months and days of the week in the presets ( Mon > Monday).
Is it possible to add an option to make the text in a circle? I think it will be relevant for the full names of months and days of the week.
In the preview, in addition to the image size, write the file name. Just in the form as it is now I thought that files will be called JAN, FEB, MAR.... But when I downloaded it I saw that the file names are convenient for further use in the editor.
Posted: 14 May 2025, 18:15
by SashaCX75
I don't know if this is a bug or intended. The transparency of the text affects the text and the shadow, but it does not affect the stroke. The stroke is always not transparent.
If you set transparency to 0, the preview does not match the uploaded files. Both the preview and the uploaded files are wrong.
Posted: 14 May 2025, 18:24
by TRK88PL
SashaCX75 wrote: 14 May 2025, 16:24
Great tool.
Small wishes.
Hi, thanks for the feedback. Let me explain everything…
I tested generating a preview in a floating window, but unfortunately it doesn’t work well—especially on small screens. Plus, it's hard to download files that way; something in the canvas doesn’t load properly and I haven’t been able to fix it.
Adding full month and day names isn’t a problem—I can do it if someone really wants it. However, shortened versions are the ones most commonly used. Besides, in this generator you can create your own words without any issue, so if someone wants to, they can easily add their own version of days and months.
Adding text along a circle is possible, but based on my tests, it doesn’t work very well. Maybe someday I’ll manage to get it working properly.
As for saving files, I specifically had your editor in mind so the files could be easily uploaded and read. It works the same way with the weather graphics.
All the best, and sorry if my answers are a bit disappointing—maybe someday I’ll revisit this and manage to add the features you suggested.
Posted: 14 May 2025, 18:33
by TRK88PL
SashaCX75 wrote: 14 May 2025, 18:15
Interesting... Can You show me screenshot of what do You mean? For me it's working as should, but maybe I'm thinking in different way and don't see something.
Posted: 14 May 2025, 18:50
by asoo
In the section of displaying characters in circle lines, I m
ade it for my own use, and I have attached an example for those who are interested to try it out or modify it further.
Multi image :
Adjusting the angle, radius, and spacing between letters :
Circle.rar
(30.32 KiB) Downloaded 127 times
I hope it will be useful for those who are interested.
Posted: 14 May 2025, 19:53
by SashaCX75
screenshots
This error probably occurs when the background colour is enabled. Here are 2 screenshots where transparency is set to 0 and 1. If transparency is 1, everything is correct on preview and in files. If transparency is 0, the text is black on preview and completely transparent in files, although it should be background colour.
Posted: 14 May 2025, 19:58
by SashaCX75
On a small screen you probably won't be able to fix the preview properly. But on a computer screen there is a lot of unused space on the sides. It would be possible to make the preview on the left or right side. Since the buttons to switch the language, so it would always be in the same place.
Posted: 17 May 2025, 17:38
by TRK88PL
Hey!
Well... I was planning to take a break, but your ideas sounded pretty cool, so I ended up seriously upgrading the generator :)
I added a live preview on the left, the ability to create angled text, and even text along a circle. It all took quite a bit of time, but I hope everything works just as smoothly for you as it does for me!
For anyone who prefers the older version, I left a link to it in the footer.
At this point, I’m not planning any more updates – there’s already so much code and so many features that I think it’s enough :)
Just a reminder: this is a text generator – you can create whatever you want. Let your imagination (and the templates) be your only limit!
P.S. If you appreciate all the hours I’ve poured into tweaking the code, feel free to buy me a coffee – there’s a link to the page on my profile.
Best regards,
Robert.
Posted: 18 May 2025, 10:19
by rush2112
@TRK88PL
Thank you so much for creating the generator to make letters, words, and more for our watch faces. We really appreciate your help!
Marc
Posted: 18 May 2025, 14:13
by SashaCX75
@TRK88PL
The preview from the side became much more convenient.
The problem with transparency equal to 0 remains. Maybe just do not allow to reduce transparency less than 1?
The text display at an angle seems to me to work incorrectly. When the knob is located at the bottom, it says that the angle is 0 degrees and the text is directed upwards. I think it is more logical that the direction of the knob coincides with the direction of the text.
In the text on the circle, I could not place it properly at the bottom of the circle. I tried switching the direction of the text. It changed. But the letters themselves remained upside down.
Posted: 18 May 2025, 14:26
by TRK88PL
Hey Sasha – if the value is 0%, then the background is cut out, as described when adjusting the color transparency. That's how it's supposed to work, and I don't want to change it, because for me it's a great solution, especially in scripts with different colors – there I use transparent text over a black or other background. So, sorry, but I’m not planning to change anything here.
As for the angle – that’s how it works in Canva, and I don’t really intend to adjust it. It’s just meant to be like that, it’s about the final position.
Also... For text on circle for me everything works fine, just adjust the settings correctly :)
That's my final version of this generator for now.
Posted: 19 May 2025, 17:00
by SashaCX75
It turns out that if transparency is 0, the image is created with a text mask. This is good, it adds features to the editor. But I would add a warning about this, because it's not the action you expect if you set the transparency to 0.
Maybe I haven't figured out the circle text settings. If that's the case, can you show an example of how to make such a text.
About the angled text. I would change the direction of its rotation to the opposite. But of course you are the author and you decide.
Posted: 20 May 2025, 08:39
by TRK88PL
Hi @SashaCX75, alright… you convinced me to make some changes, but this time it’s seriously my last update to the generator for a while.
I’ve significantly expanded the code – now there are two methods for generating angles. One is used for text shadow, gradient, and pattern, and a different one for generating angled text. The circular text has also been greatly improved – if you want the text to appear at the top, I recommend setting the letter movement to clockwise; however, if it's at the bottom, then set it to counter-clockwise.
I’ve also mentioned this in the generator in the circular text generation section. I also added information about text cutouts when opacity is set to 0%.
I hope everything now aligns with your suggestions. The new version of the generator is already live on the AmazfitWatchFaces servers :)
Best regards.
Robert.
Posted: 20 May 2025, 17:59
by SashaCX75
@TRK88PL What I wrote were only wishes, by no means demands.
I think you've implemented everything I wrote.
I noticed one peculiarity. When you set the angle of the text at the initial moment the control knob is outside the circle. But if you move it, everything works correctly. There is no such peculiarity for the shadow angle.
The link from the first post is no longer relevant and the latest version of the utility is on this site?
Posted: 20 May 2025, 18:09
by TRK88PL
@SashaCX75 new version it's available on https://amazfitwatchfaces.com/gen/
On my website I published old versions.
Edit: v3 it's available on website, more info and changelog here:
viewtopic.php?t=4699
Posted: 19 Aug 2025, 06:41
by ativirs
@TRK88PL
Can I request some new Features to be added to the image Generator?
1. Ability to create vertical weekdays.
Mon
Tue
Wed...
2. Change color of only one day in the above?
