Powerade001 wrote: 17 Sep 2022, 11:47
I you need me to test more, I am more than happy to help!
For tests, I sent several dials in private messages. If possible, write back about the results so that I can fix the editor.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
For me, the conclusion is that it is very good that I do not plan to replace the smartwatch from the GTR 3 with the GTR 4.
The annual replacement of the smartwatch loses its sense not only from the financial side, but due to the own work put into the watch faces intended for the current model.
Version 5.0.1
Mirror
Fixed work in AOD mode for GTR 4.
If you do not create watch faces for GTR 4, then you can not download this version.
扬扬fire
Post by 扬扬fire »
Hi!
When will this Watch Face Editor support GTS 4 ?
demiurg1
Post by demiurg1 »
SashaCX75, Why can't I download this version? Is she not compatible with GTR 3 watches? Should I stay with version 5.0?
扬扬fire wrote: 20 Sep 2022, 09:09
Hi!
As far as I know, watch faces from GTS 3 are suitable for GTS 4. Therefore, you can try to make watch faces for GTS 4 in this editor.
If GTS 4 owners confirm that they install GTS 3 watch faces made in this editor, I can add GTS 4 models to the selection. But this will only be for the convenience of users. There will be no difference between the GTS 4 and GTS 3 watch faces.
demiurg1
Changes in version 5.0.1 only affect the AOD mode for GTR 4 watches (possibly also GTS 4). Nothing has changed in this version for other watch versions. This update was released urgently and there was no time to test it, so I do not recommend using it unless necessary.
MasterTRL
Post by MasterTRL »
SashaCX75 wrote: 20 Sep 2022, 11:09
Can confirm. Loaded a watchface where the AOD didn´t work on my GTS 4 into 5.0.1, exported it, now AOD works fine.
扬扬fire
Post by 扬扬fire »
OK,thanks l lot!
Superwitschi
Has thanked: 8 times
Post by Superwitschi »
AOD works now fine on GTR 4, thanks !
扬扬fire
Post by 扬扬fire »
There is a problem! Where is the installation path of the watch face in the Android phone? I can't see anything watch face file in the new version of Zepp. It is not anymore for this installation path (...Android\data\com.huami.watch.hmwatchmanager\files\watch_skin_local\229)
扬扬fire wrote: 21 Sep 2022, 10:36
On new versions of Zeep, the path to watch faces is /data/user/0/com.huami.watch.hmwatchmanager/files/watch_skin_local. To see the dials you need root rights.
扬扬fire
Post by 扬扬fire »
SashaCX75 wrote: 21 Sep 2022, 12:51
Thanks a lot!. Whereas, getting root rights is a tricky business. I used another easy method ((amazfaces.apk), it is still work ) to install the watch face!
belikeKara
Post by belikeKara »
Hi Sascha I have a very weird problem with my watchfaces that contain animations and digital time. The hours display incorrectly randomly. I don't see a pattern, will correct by itself after a few minutes. Adding the leading zero to the hours seems to correct the problem.Image
Who knows it may be my watch.
bvannier
Has thanked: 10 times
Post by bvannier »
Good morning, I was used to build real 24h display for my gtr2. I don't see a way to edit my set-up and modify a few lines like it was possible before.
I would like to use digital clock for hours and analog clock for minutes and seconds, the only way to get a real 24h display.
To get access to analog and digital at the same time, I had to shut down and restart, now I can!
My only problem now is to modify two values, How can I do it?
I have to modify / ImagesCount": 24
and "DisplayFormAnalog": true
Everything seems perfect and easy to modify gtr2 to gtr4. Just import the images from an old GTR2 watchface and rebuild step by step.
Think you again to sashaCX75
Have a good day
bvannier
Here is an example how to do it
viewtopic.php?p=13414#p13414
bvannier
Post by bvannier »
Here is a first test with a try of 24h real display...
I don't have a gtr3 or gtr4, only my gtr2 so I am not sure!
The only change I made is add a line.
"img_First": "0097",
"image_length": 24,
Would you please tell me
Regards
The line added is deleted packing my watchface...
A pity
Test_gtr4_GTR_4 - Copie.zip
(967.5 KiB) Downloaded 297 times
bvannier
No, that won't work. If you want to check the operation of this method, then you need to change the "hour_array" parameter (line 194) in the ready-made dial index.js file by adding the necessary images to it
bvannier
Post by bvannier »
Think you for your patience! This time I have reached my limits... Don't know where is "in the ready-made dial index.js file" and how to modify it
So far I will stay with my gtr2
Best regards Sasha
Hopak
Post by Hopak »
Hello, I need some advice. in the attached photo is my dial that I used on the GTR3 and the battery symbol showed me the capacity. After switching to T-Rex 2,mi at 49% battery capacity, this symbol disappears, see photo 2. I use software from Sashi CX75.
Hopak
I think it would be better if you attach the dial itself. Perhaps this is some kind of peculiarity of working on the T-Rex 2.
Hopak
Post by Hopak »
Thanks for the answer, it's possible, I just wanted to know if anyone has already encountered this. I'll try to make a watch face from scratch for T-Rex 2 and then I'll let you know how it turned out.
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
I installed a free watchface from the Zepp app on my T-Rex 2 and was wondering if there's a way to export it so I can see how they produced the animation?
I have an Android phone so I'm wondering if the watchface file is on it somewhere. I'd like to get it on my laptop to give it a closer look.
The Zepp app has it listed as Astronaut Space Grey if anyone wants to check it out.
Hopak
Post by Hopak »
Unfortunately, the attempt to remake the watch face did not work, try to see where I made a mistake, in that the battery file disappears at 49%. see message from me above.
Hodinstroj.zip
(479.52 KiB) Downloaded 302 times
Hopak You misunderstood the "independent images" element. I think this is what you wanted.
Hodinstroj.zip
(481.7 KiB) Downloaded 219 times
Hopak
Post by Hopak »
I'll look into it, thanks
hi, finally problem solved. In the end, there was a problem with the Amazfitface application for Android, through which the watch face is uploaded to the watch. For some reason, I was left with the original dial without overwriting. Thanks for the help in determining the order of the png files
