分页: 9 / 9
发表于 : 09 9月 2019, 07:17
lumenvindex
Download WF_Builder 1.0.4
Changelog
代码: 全选
1.0.4
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
Re: WF_Builder (watchfaces for Mi Band 4)
发表于 : 02 11月 2020, 13:28
lumenvindex
You've tested them and they work just fine? Any of them?
发表于 : 09 11月 2020, 05:22
tari.eledhwen
Windows 10 does mean, its a worm inside, cant open at all.
发表于 : 18 11月 2020, 06:13
Tech72
Is there a mi band 5 version and if not can you change the size of the template/viewer
发表于 : 18 11月 2020, 10:24
lumenvindex
Tech72 写了: 18 11月 2020, 06:13
There is no mi band 5 version. It's not about the size of the screen. There are many changes in the syntax of .json file.
发表于 : 18 11月 2020, 18:06
Tech72
lumenvindex 写了: 18 11月 2020, 10:24
Will you be creating one
发表于 : 19 11月 2020, 02:59
lumenvindex
Tech72 写了: 18 11月 2020, 18:06
No
发表于 : 24 11月 2020, 17:09
dheerajmalviya007
Can I use it for mi band 5?
发表于 : 24 11月 2020, 17:55
lumenvindex
dheerajmalviya007 写了: 24 11月 2020, 17:09
No
发表于 : 08 1月 2021, 01:44
Sokol1991
Error when build! "WF_Builder1.0.4"
发表于 : 08 1月 2021, 06:30
lumenvindex
Sokol1991 写了: 08 1月 2021, 01:44
Looks like you've enabled one of the Section but didn't choose any image(s) for it. Hence the "Loading image -1".
发表于 : 08 1月 2021, 22:08
cygmon0
If i uncheck the "weeksday" then check it again, it doesn't show the days, even if i added files :(
idk what i did wrong.
发表于 : 09 1月 2021, 04:45
lumenvindex
cygmon0 写了: 08 1月 2021, 22:08
You add 21 files, right? Cause if you add only 7 weekday files they show up for Chineese language only.
发表于 : 08 2月 2021, 19:35
Kyoutsuvw
How do i change the size of the hour and minutes?
发表于 : 09 2月 2021, 02:14
lumenvindex
Kyoutsuvw 写了: 08 2月 2021, 19:35
Choose a set of pictures with numbers of another size. Mi Band just shows the pictures in the right order, without using any fonts or sizes.
发表于 : 09 2月 2021, 13:17
Kyoutsuvw
lumenvindex 写了: 09 2月 2021, 02:14
So it depends on the size of the picture, right?
发表于 : 03 6月 2021, 03:31
supremedap
Hi!! Is there any way of making a Day-Night cycle on the background? And also, my weekday and date only appear for a second, is there a way to fix it? Thanks for your attention.
发表于 : 08 5月 2022, 10:08
TR198ME
Nice job bro, can you make it android version of that
