Page 9 of 24
Posted: 17 Dec 2019, 17:06
by SashaCX75
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Re: GTR_WatchFace editor for Windows by SashaCX75
Posted: 10 May 2020, 22:05
by maortrol
tippo wrote: 10 May 2020, 21:49
How did you get the seconds hand to display under the other two? On the GTS it seems the seconds hand is always on top? (With hours hand on the bottom)
I have no idea how it happened, and that's what I want to fix... :lol:
I'd like to know if there is any way to choose where to put every hand... :roll:
Posted: 10 May 2020, 22:53
by Mithrel
hello, I'm using GTR_WatchFace version 8, when i packed my bin files they are over 1.95mb.
So i did a test, I downloaded a 1.6mb wachface, unpacked and did not modify it, packed again but it was 2.17mb.
Is something malfunctioning or do I have a bad application configuration?
Posted: 11 May 2020, 08:03
by SashaCX75
maortrol wrote: 10 May 2020, 10:37
I have a watch face in which Seconds hand is shown under Hours and Minutes hands (it passes below them, so when time is 0:00:00 you can't see Seconds hand, it always passes below the other two hands). Is there any way to set Minutes hand to be shown at the bottom, Hours hand at the middle, and Seconds hand at the top?
The hands are usually drawn in this order - hour hand, minute hand, second hand. If you move the second hand from the center, it will be drawn below the rest of the hands.
[mention]Mithrel[/mention]
Maybe 1.6mb is a zipped wachface. And in an unzipped state it is 2.17mb. But then it is not clear how it works. What kind of wachface did you download?
Posted: 11 May 2020, 14:32
by Mithrel
It's not ziped file. I compared the bin files without compression.
I did other test, packed with main.exe and the file is also smaller. I guess is the preview file that makes the difference, is it possible to pack bin without preview? And compressed also?
Posted: 11 May 2020, 15:36
by tippo
Mithrel wrote: 11 May 2020, 14:32
I think you can pack without a preview but I haven't tried it. I have packed with a blank preview image to try and cut down on file size and it was fine.
Posted: 11 May 2020, 16:42
by Mithrel
Animated.gif is almost 0.5mb and is always generated when packed the bin.
Then some parts of imagens dont work like day and weather
https://amazfitwatchfaces.com/gtr/view/5603
Posted: 11 May 2020, 18:15
by SashaCX75
According to your link, an unzipped file initially has a size of 2.17mb (English version). Where did you see the size 1.6mb I do not know. Some elements do not work because the size is more than 2mb. The recommended preview file size is 266x266 pixels. If you reduce the size of the preview file, then the size of the bin file should fit into the 2mb limit.
All .png files names that consist of numbers are packed into a bin file, other files are not packed into a bin.
Posted: 12 May 2020, 03:30
by Mithrel
Thanks. Is there a option to reduce the preview?
Posted: 12 May 2020, 17:38
by SashaCX75
Version 8.1
Posted: 12 May 2020, 18:08
by Mithrel
Thaks for the update
Posted: 12 May 2020, 19:20
by ManuTdi
SashaCX75 wrote: 12 May 2020, 17:38
Version 8.1
Updated translation (French, Italian, Chinese).
Did you include part of my Spanish translation?
Posted: 12 May 2020, 20:24
by tippo
Thanks for all your great work [mention]SashaCX75[/mention] !
Posted: 12 May 2020, 21:31
by SashaCX75
[mention]ManuTdi[/mention]
Yes, Included.
Posted: 13 May 2020, 09:20
by SWCI
SashaCX75 wrote: 08 May 2020, 14:07
6. ... and DND mode
Could you please explain to me what DND mode is? thanks.
Endless congratulations for the tool. Thanks
Posted: 13 May 2020, 09:26
by SashaCX75
[mention]SWCI[/mention]
DND (do not disturb) - on the watch in the blind, a crescent-shaped icon.
Posted: 14 May 2020, 00:51
by kyle
没别的意思,就是来纯支持。
No other meaning, just to come to pure support.
Posted: 20 May 2020, 17:56
by gurnoorsi366
Hi can someone make a tutorial video for it
Posted: 21 May 2020, 19:54
by taw_bip
gurnoorsi366 wrote: 20 May 2020, 17:56
Jackall Digital has a few tutorials on YouTube for the Mi Band but the general concepts are the same. The GTR watchface tool just makes it much easier and faster to put the watchface together.
https://www.youtube.com/watch?v=_j21tufMU-8
Posted: 24 May 2020, 21:02
by dasogoster
Hello, in the preview gif it looks correct and shows me all the digits, when creating the .bin and testing it in the amazfit GTS, there are some missing steps, calories and time, what could be the fault ?, thanks ...
Posted: 25 May 2020, 10:29
by maortrol
dasogoster wrote: 24 May 2020, 21:02
Check the uncompressed packed.bin file generated: it must be lesser than 1.5 MB; else, it could work wrongly in the watch.
Posted: 25 May 2020, 12:52
by juanl
Reviewing an old my sphere I observed that had defined the step target (8000). When I want to modify it with your program I notice that it does not support that field. The definition of this field is:
"Activity":
"StepsGoal":
"TopLeftX": 60,
"TopLeftY": 293,
"BottomRightX": 60,
"BottomRightY": 40,
"Alignment": "Default",
"Spacing": 1,
"ImageIndex": 12,
"ImagesCount": 10
Do you plan to include it in the next release?
Greetings.
Posted: 25 May 2020, 16:12
by SashaCX75
[mention]juanl[/mention]
If there is a need, I can add. For example, give only a working watchface where this parameter is.
Posted: 25 May 2020, 18:59
by juanl
I've put the Bumblebee sphere on the page. The dial is fully functional. You can only see the Stepsgoal statement in json if you unpack it with the old tools.
Posted: 26 May 2020, 22:07
by dasogoster
Hello, as much as I simplify it, I have removed enough images of the weather, it always keeps coming out that it occupies more than 1.5, I see more complex spheres and they work well, I do not understand it, thanks ...
Posted: 27 May 2020, 22:16
by Lordalpine
Mithrel wrote: 12 May 2020, 03:30
Preview normally is 266x266 for GTR47mm if you use the 0001.PNG [Background section -> Preview ]
You can resize it to what size you want, do a square with only the name on it... it's as you wish.
But if you want you can use a 1X1 pixel - transparent PNG for the preview if you still want to use the preview feature
or simply don't use it... you leave a blank field [ It means no picture used ] [Background section -> Preview ]
Honnestly now, I don't use it :
You can only have one custom face, I'm always on my custom face.... So^^ it save me time when I sync face to my GTR [ smaller size transfer faster ] and space on my HDD.
Open the spoiler to see an illustrated example, you can zoom on it by simply clicking it :
