Page 8 of 20
Posted: 07 Mar 2021, 10:37
by SashaCX75
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Posted: 18 May 2021, 13:29
by SashaCX75
[email protected]
There will be no preliminary calculation of the size of the dial in this version of the editor. There is no explicit dial size limitation on the watch. Watch faces are installed in a compressed form, and the compression algorithm is influenced by many factors, even the color of the pixels.
Most watch faces are up to 1MB in size. If you have all the dials larger than 5 MB, then you may be doing something wrong.
Posted: 18 May 2021, 21:09
by Guydu91
Hello Sasha,
I first wanted to thank you for the remarkable work done for the dial creation programs for GTS and GTS2 which allowed me to make some dials.
Today I have a question: is it possible, when creating an analog dial, to integrate the digital display of another time zone? (for example on this type of dial: Image ).
I think the answer can also interest GTR2 users (and why not GTR ...).
Thank you in advance for your answer.
Best regards.
Guydu91
Posted: 19 May 2021, 06:17
SashaCX75 wrote: 18 May 2021, 13:29
@[email protected]
According to the counter from the editor for GTR47, the background in 454pix and the preview in 306pix is already over 1MB
Posted: 19 May 2021, 07:40
by SashaCX75
[email protected]
What does the GTR47 editor have to do with it? If you are making a watch face for GTR47, then you are mistaken in the forum topic.
Guydu91
It is possible to draw hands at an angle for the analog time and then the analog clock readings will lag behind or ahead of the main time.
Posted: 19 May 2021, 10:39
SashaCX75 wrote: 19 May 2021, 07:40
@[email protected]
I only used it to check the size of the files. This is due to the suspicion that the size of the dial affects battery consumption.
Posted: 19 May 2021, 15:13
by CASIONFAN2021
Thanks to sasha for this amazing product. I would ask that there be an update to the watch face editor 2 for the t rex pro that allows the entries for moon phase and the sunrise sunset that is present on the stock watch faces. Is that possible?
Posted: 20 May 2021, 15:36
by SashaCX75
By standard dials, are you referring to dials embedded in watches or dials from Zepp? If Zepp has a moon phase dial, send it for a sample.
Posted: 21 May 2021, 10:15
by spidercrab
I noticed that one of the built-in WFs in the TRexPro has a Moon Phase display.
Posted: 22 May 2021, 15:29
by gengtrex
hi sasha. thanks again for all of your amazing editors.
just a quick question, is it possible to put an animation into t-rex pro SOON? or converted from t-rex?
does t-rex pro system support that?
Posted: 22 May 2021, 16:17
by SashaCX75
GTR 2 does not support animation. I think T-Rex Pro doesn't support animation either.
Posted: 22 May 2021, 20:29
by demiurg1
Does anyone know if active (touch) fields (shortcuts) will be available in the design of watch faces for the GTR 2, as in the GTR 47?
I tried, but nothing came of it. I also did not find any such ready-made watch face.
Posted: 23 May 2021, 02:47
by gengtrex
SashaCX75 wrote: 22 May 2021, 16:17
thanks for your info, sasha. :)
Posted: 23 May 2021, 08:30
by SashaCX75
Posted: 23 May 2021, 16:06
by Dryttw2234
Hi
I would like you to add a menu. Can you animation?
I can't animate the watch face.
Same Amazfit GTS
Posted: 23 May 2021, 16:37
by pablorito14
Hi. How can i make faces to GTS 2 mini? huami dev page request identificacion picture but I don't know if it's safe
Posted: 24 May 2021, 09:13
by demiurg1
SashaCX75 wrote: 23 May 2021, 08:30
Thanks for the info.
Posted: 24 May 2021, 10:31
by CASIONFAN2021
T rex pro editor could do with an update, barometer does not pull the figures from the watch. Sunrise sunset and moon phase need to be added. Have sent a pm to sasha asking about the possibility. I mentioned I would quite happily donate money to an update for these features missing for t rex pro faces.
Posted: 25 May 2021, 14:25
by eudald.bellmunt
Firs of all, thanks for this great tool to create GTS2 Watchfaces.
I am using this tool to create a watchface but I found a little issue that maybe is not possible to solve.
Let me explain.... I tring to put two 'big' images of the segonds very closer, and I am uing the 'Spacing' parameter to put them closer.
I fond out that this parameter is going up to -127 and then start again like 0 (but really the parameter is -128). I guess that maybe is because it is a byte size and there is not possible to setup greater nunber. But maybe it is a little bug. I apreciate that if it is a bug we can arrange it.
Thanks again for this tool!
Posted: 25 May 2021, 14:55
by SashaCX75
eudald.bellmunt
Indeed, the preview with the 'Spacing' parameter value equal to -128 is displayed incorrectly. Will be fixed in future versions.
For GTR 2 'Spacing' varies from -128 to 127, I think for GTS2 as well.
Posted: 27 May 2021, 09:03
by win009
How can I convert my t-rex file into t-rex pro
Posted: 27 May 2021, 19:51
by ig67754
spidercrab wrote: 21 May 2021, 10:15
Shortcuts also work in original faces T-rex pro.
Posted: 27 May 2021, 20:02
by ig67754
Hi, on my T-rex pro the shortcuts work on the original dials as pictured above for example in the spidercrab post.
Posted: 29 May 2021, 03:52
by synar
Dear Sasha!
I found a very intresting wf.
https://4pda.to/forum/index.php?showtop ... =107019856
Will be available these new functions ("FontRotate", "Sunrise", etc.) in your next editor 2 version?
Thanks a lot for these great previous versions too.
Posted: 29 May 2021, 05:37
by synar
... And how can i make backgound image selectable from built-in color variations, like as this wf below?
Wow, I see in the json:
"Widgets"...
"Activity"...
"Weather"...
"Icon"...
Very clever, and would be greate possibilities in the future :)
Posted: 29 May 2021, 08:06
by SashaCX75
I already wrote about shortcuts and animations. We need a file with a dial where these elements work. Then we can figure out how this is done. If the Zepp program for your watch model has such a dial, then you can pull it out. Such a dial cannot be pulled out from the watch itself.
In dials ported from GTR (GTS, T-Rex) shortcuts work. But many other elements do not work in such dials, so I do not plan to develop these areas further.
The next version will add support for sunrise, the system font. There is support for widgets in the plans, but not in the nearest versions.
