Amazfit watchfaces Tool
JotaEme
Messaggio da JotaEme »
caconym64 ha scritto: 18 set 2019, 17:42
put all watchface files (png images and json file) into python tools folder
run 'cmd' and cd to python tools folder
run command: python main.py --gtr <watchface name>.json
the new watchface bin file should be created, along with a log and preview images
FYI, if you create a shortcut to main.py on the desktop, you can keep all the watchface files on a separate folder. Then, drag the json file to that shortcut and it will create the bin and previews inside the watchface folder. It's tidier.
koolgao
Messaggio da koolgao »
buenos dias compañero sabeis si ahi alguna aplicacion para empacar y desempacar las wf de los gtr de 42mm? gracias de antemano
caconym64
Messaggio da caconym64 »
JotaEme ha scritto: 19 set 2019, 14:35
FYI, if you create a shortcut to mainpy on the desktop, you can keep all the watchface files on a separate folder. Then, drag the json file to that shortcut and it will create the bin and previews inside the watchface folder. It's tidier.
Nice tip - I'll give that a try, thanks.
pacomar
Messaggio da pacomar »
how can i put weather intructions por amazfit gtr? is it possible? thanks in advance.
Son38
Messaggio da Son38 »
Good morning! I have a gtr42, anda i can't Make a watchface. Is there any tool for this device?
Ripo power
Messaggio da Ripo power »
Could someone share a tutorial that of how to convert a GTR WF to verge lite using amazfit tool?
Thank you friends
hall
Messaggio da hall »
anybody know .json syntax for heartrate with include icon? I know how to do with Steps as below. The icon will move along with number. The purpose i asked here is because i want heartrate icon with number in the center of dedicate area as sometimes heartrate is 2 digits or 3 digits.
"Steps": {
"Step": {
"TopLeftX": 140,
"TopLeftY": 56,
"BottomRightX": 314,
"BottomRightY": 82,
"Alignment": "TopCenter",
"Spacing": 0,
"ImageIndex": 12,
"ImagesCount": 10
"ImageIndex": 22
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Messaggio da osmat »
Dear users, we temporarily stop supporting the Amazfit Watch Faces Tool. You can find the current version in the first message. Link to the source there. A more stable tool for creating watch faces you can find in this topic
viewtopic.php?f=29&t=816&p=2313#p2313
Amazfit verge lite / gtr supported
All thanks to the original author: afwafwafw
If you are a developer or you have ideas on how to help the community, be sure to contact us.
We will be happy to work with everyone.
Bloccato
Torna a “Closed topics”
