lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
Caz
Post by Caz »
Caz
Post by Caz »
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Time": {
"Hours": {
"Tens": {
"X": 6,
"Y": 27,
"ImageIndex": 1,
"ImagesCount": 3
"Ones": {
"X": 29,
"Y": 27,
"ImageIndex": 1,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 65,
"Y": 27,
"ImageIndex": 1,
"ImagesCount": 6
"Ones": {
"X": 93,
"Y": 27,
"ImageIndex": 1,
"ImagesCount": 10
"Activity": {
"Steps": {
"Number": {
"TopLeftX": 10,
"TopLeftY": 128,
"BottomRightX": 116,
"BottomRightY": 229,
"Alignment": "BottomCenter",
"Spacing": 3,
"ImageIndex": 11,
"ImagesCount": 10
"Pulse": {
"Number": {
"TopLeftX": 81,
"TopLeftY": 196,
"BottomRightX": 0,
"BottomRightY": 0,
"Alignment": "TopLeft",
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
"NoDataImageIndex": 21
"Distance": {
"Number": {
"TopLeftX": 35,
"TopLeftY": 196,
"BottomRightX": 0,
"BottomRightY": 0,
"Spacing": 0,
"ImageIndex": 31,
"ImagesCount": 10
"SuffixImageIndex": 31,
"DecimalPointImageIndex": 111
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 88,
"TopLeftY": 72,
"BottomRightX": 125,
"BottomRightY": 210,
"Spacing": 3,
"ImageIndex": 41,
"ImagesCount": 10
"Day": {
"TopLeftX": -2,
"TopLeftY": 72,
"BottomRightX": 74,
"Alignment": "TopRight",
"Spacing": 3,
"ImageIndex": 41,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 12,
"Y": 73,
"ImageIndex": 89,
"ImagesCount": 21
"StepsProgress": {
"Linear": {
"StartImageIndex": 51,
"Segments": [
"X": 0,
"Y": 235
"X": 10,
"Y": 235
"X": 20,
"Y": 235
"X": 30,
"Y": 235
"X": 40,
"Y": 235
"X": 50,
"Y": 235
"X": 60,
"Y": 235
"X": 70,
"Y": 235
"X": 80,
"Y": 235
"X": 90,
"Y": 235
"X": 100,
"Y": 235
"X": 110,
"Y": 235
"Status": {
"Bluetooth": {
"Coordinates": {
"X": 41,
"Y": 6,
"BoxWidth": 15,
"Alignment": "Left",
"Order": 1
"ImageIndexOff": 110
"Battery": {
"BatteryConfig": {
"BoxWidth": 1,
"Alignment": 0,
"Order": 1
"Text": {
"TopLeftX": 69,
"TopLeftY": 7,
"BottomRightX": 0,
"BottomRightY": 0,
"Spacing": 0,
"ImageIndex": 63,
"ImagesCount": 10
"Icon": {
"X": 98,
"Y": 6,
"ImageIndex": 73,
"ImagesCount": 9
"Other": {
"Animation": {
"AnimationImage": {
"X": 0,
"Y": 0,
"ImageIndex": 82,
"ImagesCount": 7,
"x3": 0
"Speed": 0,
"RepeatCount": 0,
"x2": 100
Caz
Post by Caz »
bin file
SCORPIO_BOLT2_Palette.bin
(140.67 KiB) Downloaded 317 times
lumenvindex
Caz wrote: 26 Jan 2020, 12:26
"Speed": 0,
"RepeatCount": 0,
"I play animation 0 times at 0 speed. Why isn't animation working?"
You should have RepeatCount = 1 and the speed should be at least 4 (or the animation won't move, it's a firmware bug).
You should read something about watchface making. All of your questions aren't about WF_Builder. :D
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
Thanks that worked, great stuff
thats the thing see, when i ask you a question, i can understand your answer, i carry it out and it works lol
i have been reading up on WF making but its a lot to take in and if i am honest i only understand a quater of it :oops:
i find i learn more by trial and error it sinks in and means something, thanks to you i have now found out how to add miles, to make PNG files for animation small and to use pngquant and to check animation is set to run 1 time and to set speed to at least 4
thanks again for your help
caz
Dragos
Post by Dragos »
Can add weather in this builder..?
lumenvindex
Dragos wrote: 31 Jan 2020, 13:16
No. Weather cannot be displayed on Mi Band 4. Hence there is no need to add weather to watchface.
MESS WITH THE BEST
DIE LIKE THE REST
Soaresden
Post by Soaresden »
First I want to thanks you for making this tool.
I begin learning VB net only for this purpose, and you did it very better than me ^^
(just you to see my horrible thing : https://geekdoing.com/threads/mi-band-4 ... -net.1127/)
So i started editing it and was good looking for me.
The only thing is, I don't know why informations keeps "disappearing" after 2 seconds.
See the vid below in action :
https://streamable.com/pcvlo
Thanks for any answer or piece of explanations
I'll join the project too
My Exemple.zip
Here the file
(71.07 KiB) Downloaded 296 times
lumenvindex
Soaresden wrote: 17 Feb 2020, 13:51
Hi. Read here.
MESS WITH THE BEST
DIE LIKE THE REST
tigre652
Post by tigre652 »
Is there always a MI BAND firmware bug that after 1 second the information disappears? The time is always displayed but the heartbeats, steps, the day of the week and the logo disappear. It cannot be resolved. Other watchfaces don't have this problem.
I put 2 versions of the video, in the most recent one the battery remains on the screen. Thank you
old video https://youtu.be/TTTPZTc50R4
new video https://youtu.be/1kxYiDUPoNU
lumenvindex
tigre652 wrote: 03 Mar 2020, 10:04
Don't know anything about most recent firmwares.
Maybe the order of elements has changed. Seconds redrawing wipes out data that is drawn after it.
MESS WITH THE BEST
DIE LIKE THE REST
tigre652
Post by tigre652 »
Ok, Thank's
Vojta_CZE
Post by Vojta_CZE »
How to download watchface builder
Has thanked: 1162 times
Been thanked: 279 times
Vojta_CZE wrote: 05 Mar 2020, 16:08
https://yadi.sk/d/FrdIdbQSudu9eg
Sam70077
Post by Sam70077 »
How to make watchface server?
lumenvindex
Sam70077 wrote: 08 Mar 2020, 05:40
Don't know what you are talking about. This program helps building a watchface, that's all.
MESS WITH THE BEST
DIE LIKE THE REST
yummykoreans
Post by yummykoreans »
Hello! Can You help me?
I tried to open this Program: WF_Builder 1.0.4 .exe
But Shows "Windows cannot access the specified device, path, or file" So i turn off Some windows Antivirus firewall and virus detector.
but still not work. what can I do? Even Administrator Access not work...
lumenvindex
How can I help you?
Program works just fine on any OS from Windows XP to Windows 10. The message you get looks like the result of some antivirus activity which holds the exe-file.
MESS WITH THE BEST
DIE LIKE THE REST
missmolotov
Post by missmolotov »
Is there more to this error than pure filesize?
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:337kb
I started making a watchface, using the Raw Image Mode tool. My first background image was 3.34kb and the .bin file was packed fine.
My second background image had a tiny amount more text added (the word 'steps') and was also 3.34kb in size, but this error was thrown.
If I use the pngquant tool as suggest by another use, I can get the filesize down to 1.9kb, but the same error is still thrown by the Raw Image Tool.
I can get the .bin file to pack if I use the Pallet Tool, but the edges of the image come out all jaggy.
If I put the image onto a black background instead of making it transparent, the filesize goes up to 4.61kb, but the .bin file will pack with the Raw Image Tool just fine!
It doesn't seem to be a size vs file size on disk issue, because all the files are counted as 4kb on disk.
I feel like the error message being thrown isn't accurate or isn't describing the exact issue. I am wondering, what specifically is the tool looking at when it creates that error? I wonder if there is something else more to know which would help with deciding how best to make background image files?
Thanks for reading and too the tool maker for all your hard work on this tool. I have been enjoying using it a lot up until this point.
lumenvindex
missmolotov wrote: 31 Mar 2020, 03:07
Pngquant is good for reducing the image's total colors count. It is good for Palette, but It's totally useless if you pack it Raw.
And forget about the PNG sizes. Images aren't stored in PNG format inside the resulting BIN.
If you want to pack a watchface in Palette mode having numbers with transparent background, you can try using Stroke effect (outer, 1px, pick a colour similar to background) on each number image. The edge will still get jaggy after Palette packing, but you will hardly notice it on Mi Band.
MESS WITH THE BEST
DIE LIKE THE REST
hellllllooooooo
Post by hellllllooooooo »
Dandow wrote: 09 Sep 2019, 12:44
That's awesome!
Thanks a lot, i'll test it today.
I was wondering, did you contemplated "gif"?
How do i make a honor band 5 face plz help
Benjamin1983
Post by Benjamin1983 »
buenas, ay alguna manera de poner capas delante o detras segun gusto de cada uno
lumenvindex
Benjamin1983 wrote: 10 Jun 2020, 21:29
No se puede cambiar el orden de las capas.
There is no way to change the order of layers.
MESS WITH THE BEST
DIE LIKE THE REST
anhtu7596
Post by anhtu7596 »
Please create a tool like this for miband5
